查看: 3799|回复: 11
[求助] innovus导出gds后lvs存在错误该怎么解决?
发表于 2023-11-20 19:26:03 | 显示全部楼层 |阅读模式
考虑时钟走线问题,我就把几个子模块一起放top整体综合了,子模块都能过,但是整个就有问题。
我重复例化了好几个子模块c,只有第一个的SEL_CNT信号有问题,我把第一个例化注释掉就没有这个错误了。
Discrepancy #1 in channel
Net VDD                                                   VDD
--- 8532 Connections On This Net ---                      --- 8546 Connections On This Net ---
** missing connection **                                  (_sdw3v):in3
                                                            Xinst_d_d7_reg/MM7:g
** missing connection **                                  (_sup2v):in2
                                                            Xinst_d_d7_reg/MM8:g
                                                            Xinst_d_d2_reg/MM7:g
                                                            Xinst_d_d2_reg/MM8:g
                                                            Xinst_d_d6_reg/MM7:g
                                                            Xinst_d_d6_reg/MM8:g
                                                            Xinst_d_d4_reg/MM7:g
                                                            Xinst_d_d4_reg/MM8:g
                                                            Xinst_d_d5_reg/MM7:g
                                                            Xinst_d_d5_reg/MM8:g
                                                            Xinst_d_d1_reg/MM7:g
                                                            Xinst_d_d1_reg/MM8:g
                                                            Xinst_d_d3_reg/MM7:g
                                                            Xinst_d_d3_reg/MM8:g
Discrepancy #2 in channel
Net SEL_CNT                                               SEL_CNT
--- 102 Connections On This Net ---                       --- 96 Connections On This Net ---
(SPDW_2_1_1):input                                        ** missing connection **
  X1508/X1/M0(16.365,273.830):g
(SPUP_2_1):input                                          ** missing connection **
  X1797/M6(17.375,268.935):g
(_smn2v):in2                                              ** missing connection **
  X1797/M2(17.455,267.555):g
(_sup2v):in1                                              ** missing connection **
  X1508/X1/M4(16.315,275.865):g
(_nand2v):in1                                             ** missing connection **
  X1523/M5(9.305,271.565):g
  X1523/M1(9.480,273.145):g
(_nand2v):in2                                             ** missing connection **
  X1508/X0/M3(17.585,275.355):g
  X1508/X0/M1(17.705,274.200):g
(_invv)ut                                               ** missing connection **
  X2156/M14(13.695,273.730):s
  X2156/M28(13.695,275.220):s
** missing connection **                                  (SPUP_2_2):input
                                                            Xg13331/MM0:g
子模块d都多一条线,看了下是这个输入线
Discrepancy #3 in channel
Net 1882                                                  ** no similar net **
Discrepancy #4 in channel
Net 1883                                                  ** no similar net **
Discrepancy #5 in channel
Net 1884                                                  ** no similar net **
Discrepancy #6 in channel
Net 1885                                                  ** no similar net **
Discrepancy #7 in channel
Net 1886                                                  ** no similar net **
Discrepancy #8 in channel
Net X2710/D                                               ** no similar net **
Discrepancy #9 in channel
Net X2711/D                                               ** no similar net **
#####incorrect instance:
Discrepancy #11 in channel
(SPUP_2_1)                                                ** missing gate **
Transistors:
  X1797/M4(16.440,268.935)  MP(P12)
  X1797/M5(16.865,268.935)  MP(P12)
  X1797/M6(17.375,268.935)  MP(P12)
Discrepancy #12 in channel
** missing gate **                                        (SPUP_2_2)
                                                          Transistors:
                                                            Xg13331/MM7  MP(P12)
                                                            Xg13331/MM5  MP(P12)
                                                            Xg13331/MM8  MP(P12)
                                                            Xg13331/MM0  MP(P12)
 楼主| 发表于 2023-11-20 19:27:03 | 显示全部楼层
C:\Users\12985\Pictures\Screenshots\屏幕截图 2023-11-20 184535.png
 楼主| 发表于 2023-11-20 19:28:46 | 显示全部楼层
子模块d的几个实例都是多了这个输入线连接
 楼主| 发表于 2023-11-20 19:36:49 | 显示全部楼层
发表于 2023-11-21 09:42:17 | 显示全部楼层
看一下extract report看有没有warning,error
 楼主| 发表于 2023-11-21 14:51:09 | 显示全部楼层
这个是lvs报告,能麻烦您看一下吗?
channel.lvs.report.txt
66.57 KB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2023-11-21 16:58:20 | 显示全部楼层
你instance都没对上
 楼主| 发表于 2023-11-21 17:54:58 | 显示全部楼层
awesomewalle 发表于 2023-11-21 16:58
你instance都没对上
请问这种情况是综合出了问题还是布局布线出了问题?
发表于 2023-11-22 09:45:11 | 显示全部楼层
dddddyx 发表于 2023-11-21 14:51
这个是lvs报告,能麻烦您看一下吗?
我说的是extract报告,不是lvs报告。再者你看一下VDD有没有连对,从layout找一下这几个的gate端
 楼主| 发表于 2023-11-23 10:24:37 | 显示全部楼层
版图上栅极都没有和VDD连起来,另:我找了.lvs.report.ext,里面啥也没有
点评
请问您最后怎么解决的呢?我遇到了同样的问题,也是子模块可以过,而且电路图和网表连线都没问题  发表于 2024-4-29 20:14
GMT+8, 2025-12-25 12:55 , Processed in 0.054918 second(s), 8 queries , Gzip On, Redis On.
