查看: 2209|回复: 1
[转贴] PSS中shooting与Harmonic balance区别,转载
发表于 2023-10-12 17:35:54 | 显示全部楼层 |阅读模式
Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooting Newton Engine?
Shooting Newton (shooting) and harmonic balance (HB) are complementary technologies and used for circuits that exhibit different behaviors.
The shooting Newton algorithm uses an adaptive time step control, which is particularly effective for sharp transitions. Convergence is robust and not as sensitive to model imperfections.
Harmonic balance is much faster for mildly nonlinear circuits. When the simulation parameters are set up properly, both should give accurate, very similar results (however, since the algorithms used are not identical, the results will not be identical).
Use harmonic balance for:
  • High dynamic range, weakly-nonlinear systems
    • RF front-ends (LNA, Mixer)
    • IQ modulators
  • Mildly nonlinear oscillators with resonators, such as
    • LC oscillators
    • Crystal oscillators
    • Negative-gain oscillators
  • Circuits with distributed components
    • Transmission lines
    • S-parameter models
Use shooting Newton for:
  • Circuits where input signals have sharp transitions
  • Strongly nonlinear circuits
    • Frequency dividers
    • Strongly-nonlinear resonatorless oscillators, such as
      • Ring oscillators,
      • Relaxation oscillators,
      • Oscillators containing digital control components,
      • Oscillators with dividers.
Important Note -- if simulating oscillators, see:
http://sourcelink.cadence.com solution 11480630 - Guidelines for Simulating Oscillators in SpectreRF MMSIM 7.0.1
https://community.cadence.com/ca ... oting-newton-engine
 楼主| 发表于 2023-10-12 17:39:38 | 显示全部楼层
shooting 和 hb是两种不同的算法,shooting是基于时域分析后傅立叶变换得到频域,hb是基于谐波分析的频域分析,max是考虑的最大谐波频率,会混频到基频附近,高于这个值的就不再考虑了,至于beat frequency,可以计算得到,也可以先仿真个tran得到
GMT+8, 2025-12-26 20:45 , Processed in 0.016082 second(s), 3 queries , Gzip On, Redis On.
