查看: 5482|回复: 13
Altair PSIM Professional 2023 with Full Features
发表于 2023-9-30 01:28:54 | 显示全部楼层 |阅读模式
PSIM program for designing and modeling power electronics and motor control devices. Power electronics simulation in PSIM provides high simulation speed while providing high quality results at the system level.  Verification and simulation in PSIM  The design verification process in the early stages of design is critical to ensure a reliable product design. PSIM provides a wide range of design validation tools:
Monte Carlo Analysis. This is a statistical analysis that calculates the response of the circuit when the parameters of the components change randomly according to a given statistical distribution (eg, normal (Gaussian) distribution, uniform distribution, etc.). Monte Carlo analysis can be used to evaluate the effect of key component changes on the output power of a power converter. A change in a component may be the result of a manufacturing tolerance or the wear of a component over time. Monte Carlo analysis is recommended to understand what tolerances key components should have.  Sensitivity Analysis allows you to determine how the output characteristics of a circuit change when one or more of its components change. This analysis is often used to determine the most sensitive key components in a chain.
Fault Analysis allows you to analyze the performance of a circuit under fault conditions such as a short circuit or an open circuit in a component. Failure analysis helps evaluate whether a design can pass various failure tests and whether a particular failure could lead to catastrophic consequences.  The results of design verification can greatly help an engineer evaluate and improve the performance and reliability of a design.  Inline code generation  SimCoder automatically generates high quality C code from the PSIM control circuit. Automatic code generation eliminates human error and improves design speed, reduces development costs, and speeds time to market.  Thermal simulation
For switching devices (diodes, MOSFETs, IGBTs), thermal simulation allows you to calculate losses either under a fixed temperature effect or when heat is dissipated through a heatsink thermal equivalent circuit. Thermal analysis will ensure that devices remain in a safe work area. Starting with PSIM 11, the user can simulate the characteristics of wide bandgap semiconductors - SiC and GaN - using a MOSFET (Eon).  The PSIM core and winding losses for inductors are based on core dimensions, winding physical structure, etc., to account for complex relationships such as the proximity effect. Loss calculations depend on temperature, and models use junction temperature or core temperature to reflect this dependence.  PSIM functionality  Analyzing and designing complex drive systems
Dramatically speed up your drive design process—quickly and easily. PSIM provides powerful tools for the design, simulation and analysis of electric drives. –  Evaluation of engine performance.  – Current/speed feedback controller design:  • Touch or sensorless control, FOC/DTC .  – Dimensioning the main components of the power converter:  • Calculating inverter losses and comparing devices.  • DC bus size and size. coupling capacitor.  • EMI filter evaluation.  Power supplies  – Evaluation of multiple topologies and converter performance:  • Worst case analysis and Monte Carlo analysis.  • Frequency analysis.  • Sensitivity and failure analysis. – Switching speed and its effect on:
• Dimensions of magnets and capacitors.
• Strength and losses in components.
• Electromagnetic interference.  – Development and operation of the electromagnetic interference (EMI) filter.  – Design and implementation of the control system:  Analog  or digital  • Bandwidth  • Implementation and validation of digital control  • Rapid Control Prototyping (RCP)  Batteries, Photovoltaics, Wind turbines
Energy storage and generation are becoming increasingly important as the grid becomes more distributed and renewables make up an increasing share of electricity generation. Users of PSIM solutions use battery and photovoltaic (PV) models for microgrids, satellite power flow simulations, electric vehicle (EV) All car models have 4 quadrants, allowing you to "move" or "generate". Use this feature to simulate an electric vehicle propulsion system with drive cycles and regenerative braking, or combine it with our wind turbine model to simulate a wind power system.  Key features of the model include:  • Various battery models: look-up table based, equation based, variable charge/discharge resistance, etc.  • Various photovoltaic models: based on technical data, normalized based on standards.
Download Link:
https://rutracker.org/forum/viewtopic.php?t=6415305
For more information on the following packages:
PowerFactory 2023, ETAP 22.5 (2023 Version), SKM Power Tools 10.0.0.5, SKM GroundMat 2.0.2, PSS Sincal 19.0, PVSOL Premium 2023, CDEGS 17.0, PLSCAD 16.81, EMTP 4.2.1, PSCAD 5.0.1, PSSE 35.5, and CYMCAP 8.1. Please contact fast.forever24@gmail.com
发表于 2023-9-30 06:03:00 | 显示全部楼层
thanks
发表于 2023-9-30 10:39:20 | 显示全部楼层
发表于 2023-9-30 11:43:53 | 显示全部楼层
suiwinder 发表于 2023-9-30 10:39
https://rutracker.org/forum/viewtopic.php?t=6415305,网站上不去了啊
thanks for free link, good work
发表于 2023-9-30 17:10:02 | 显示全部楼层
https://rutracker.net/forum/viewtopic.php?t=6415305
发表于 2023-10-3 08:53:41 | 显示全部楼层
领先的电力电子和电机驱动仿真与设计。
Share from eetop : 2022.3.0、2022.2.0、2022.1.0
https://pan.baidu.com/s/1P15_sH6WTxZwL1x-G0MuaQ?pwd=fzzl
发表于 2023-10-3 16:48:35 | 显示全部楼层
thanks
发表于 2023-10-4 00:18:42 | 显示全部楼层
xiexie57 发表于 2023-10-3 08:53
领先的电力电子和电机驱动仿真与设计。
Thank you
发表于 2023-10-4 11:26:03 | 显示全部楼层
学习一下,谢谢!
发表于 2023-10-5 16:10:06 | 显示全部楼层
magnet:?xt=urn:btih:E666F4E71CA521B6C3F19E1114B099EF7F0A9446&tr=http%3A%2F%2Fbt2.t-ru.org%2Fann%3Fmagnet&dn=Altair%20PSIM%202023.0%20Win64%20%5B2023%2C%20ENG%5D
GMT+8, 2025-12-30 09:15 , Processed in 0.020517 second(s), 4 queries , Gzip On, Redis On.
