查看: 1594|回复: 0
[原创] 基于Cy7c68000的USB2.0 IP Debugging
发表于 2023-9-2 10:13:48 | 显示全部楼层 |阅读模式
1 . USB2.0 IP 来自opencore ,在此基础上设计,主要实现了MCU功能,用verilog实现。https://www.bilibili.com/video/B ... a77fd93decce4a32a63
2. 综合下载到Malogic FPGA Board 上,模拟U Disk 实现盘符,稍后会出视频。
3. 在店铺购买Malogic FPGA Board , https://item.taobao.com/item.htm ... amp;id=717924064672
4. IP 介绍:
### USB Peripheral Interface
Github:   [http://github.com/ultraembedded/cores](https://github.com/ultraembedded/cores/tree/master/usb_device)
This component is a simple USB Peripheral Interface (Device) implementation with an AXI4-Lite slave register interface,
and with a UTMI interface for connection to a USB PHY.
It has been designed to support USB2.0, but currently has been only tested in Full Speed peripheral mode (12Mbit/s).
##### Features
* USB 2.0 Device mode support.
* Simple register data read/write interface (low performance / not DMA based).
* UTMI PHY interface (see my UTMI to ULPI Conversion wrapper project to allow connection to a ULPI PHY e.g. USB3300)
* Current build configuration has 4 endpoints
##### Limitations
* Only tested for USB-FS (Full Speed / 12Mbit/s) only.
* AXI4-L address and data must arrive in the same cycle.
##### Software
Provided with a USB-CDC test stack (USB Serial port) with loopback/echo example.
To make this functional on your platform;
* Set USB_DEV_BASE to the correct address for the peripheral.
* Implement the millisecond timer functions in timer.h.
* Change USB_BYTE_SWAP16 in usbf_defs.h if your CPU is big endian.
##### Testing
Verified under simulation then tested on FPGA as a USB-CDC mode peripheral (USB serial port) against Linux & Windows PCs.
##### References
* [USB 2.0 Specification](https://usb.org/developers/docs/usb20_docs)
* [UTMI Specification](https://www.intel.com/content/da ... e-specification.pdf)
* [USB Made Simple](http://www.usbmadesimple.co.uk/)
* [UTMI to ULPI Conversion](https://github.com/ultraembedded/cores/tree/master/ulpi_wrapper)
##### Register Map
| Offset | Name | Description   |
| 0x00 | USB_FUNC_CTRL | [RW] Control Register |
| 0x04 | USB_FUNC_STAT | [RW] Status Register |
| 0x08 | USB_FUNC_ADDR | [RW] Address Register |
| 0x0c | USB_EP0_CFG | [RW] Endpoint 0 Configuration |
| 0x10 | USB_EP0_TX_CTRL | [RW] Endpoint 0 Tx Control |
| 0x14 | USB_EP0_RX_CTRL | [W] Endpoint 0 Rx Control |
| 0x18 | USB_EP0_STS | [R] Endpoint 0 status |
| 0x1c | USB_EP0_DATA | [RW] Endpoint Data FIFO |
| 0x20 | USB_EP1_CFG | [RW] Endpoint 1 Configuration |
| 0x24 | USB_EP1_TX_CTRL | [RW] Endpoint 1 Tx Control |
| 0x28 | USB_EP1_RX_CTRL | [W] Endpoint 1 Rx Control |
| 0x2c | USB_EP1_STS | [R] Endpoint 1 status |
| 0x30 | USB_EP1_DATA | [RW] Endpoint Data FIFO |
| 0x34 | USB_EP2_CFG | [RW] Endpoint 2 Configuration |
| 0x38 | USB_EP2_TX_CTRL | [RW] Endpoint 2 Tx Control |
| 0x3c | USB_EP2_RX_CTRL | [W] Endpoint 2 Rx Control |
| 0x40 | USB_EP2_STS | [R] Endpoint 2 status |
| 0x44 | USB_EP2_DATA | [RW] Endpoint Data FIFO |
| 0x48 | USB_EP3_CFG | [RW] Endpoint 3 Configuration |
| 0x4c | USB_EP3_TX_CTRL | [RW] Endpoint 3 Tx Control |
| 0x50 | USB_EP3_RX_CTRL | [W] Endpoint 3 Rx Control |
| 0x54 | USB_EP3_STS | [R] Endpoint 3 status |
| 0x58 | USB_EP3_DATA | [RW] Endpoint Data FIFO |
##### Register: USB_FUNC_CTRL
| Bits | Name | Description    |
| 8 | HS_CHIRP_EN | High-speed Chirp Enable | 0
| 7 | PHY_DMPULLDOWN | UTMI PHY D- Pulldown Enable | 1
| 6 | PHY_DPPULLDOWN | UTMI PHY D+ Pulldown Enable | 0
| 5 | PHY_TERMSELECT | UTMI PHY Termination Select | 1
| 4
3 | PHY_XCVRSELECT | UTMI PHY Transceiver Select | 1
| 2:1 | PHY_OPMODE | UTMI PHY Output Mode | 00
| 0 | INT_EN_SOF | Interrupt enable - SOF reception | 0
##### Register: USB_FUNC_STAT 04
| 13 | RST | USB Reset Detected (cleared on write) |
| 12:11 | LINESTATE | USB line state (bit 1 = D+, bit 0 = D-) | RO
| 10:0 | FRAME | Frame number | RO
##### Register: USB_FUNC_ADDR
| 6:0 | DEV_ADDR | Device address |
##### Register: USB_EPx_CFG
| 3 | INT_RX | Interrupt on Rx ready |  RX完成中断使能
| 2 | INT_TX | Interrupt on Tx complete | TX完成中断使能
| 1 | STALL_EP | Stall endpoint |
| 0 | ISO | Isochronous endpoint |
##### Register: USB_EPx_TX_CTRL  0x10=ep0
| 17 | TX_FLUSH | Invalidate Tx buffer |复位为0,写1:读/写地址清零;W/R
| 16 | TX_START | Transmit start - enable transmit of endpoint data |
      复位为0,写1:启动传输,自动清零,通过TX_BUSY判断传输是否完成;W
| 10:0 | TX_LEN | Transmit length | IN包,传输包长,
##### Register: USB_EPx_RX_CTRL 0x14=ep0
| 1 | RX_FLUSH | Invalidate Rx buffer |复位为0,写1:读/写地址清零;W/R
| 0 | RX_ACCEPT | Receive data accepted (read) |复位为0,
     写1:RX_READY清零,RX_COUNT清零,RX_SETUP清零,RX_ERR清零;W/R
##### Register: USB_EPx_STS 0x18=ep0
| 20 | TX_ERR | Transmit error (buffer underrun) |
| 19 | TX_BUSY | Transmit busy (active) |  复位为0,1为busy;只读
| 18 | RX_ERR | Receive error - CRC mismatch or buffer overflow |
| 17 | RX_SETUP | SETUP request received |  复位为0,1为收到setup;只读
| 16 | RX_READY | Receive ready (data available) |复位为0,1为收到包;只读
| 10:0 | RX_COUNT | Endpoint received length (RD) |复位为0,收到的包长度;只读
##### Register: USB_EPx_DATA
| Bits | Name | Description    | 0x1c=ep0
| 7:0 | DATA | Read or write from Rx or Tx endpoint FIFO |
GMT+8, 2025-12-25 18:43 , Processed in 0.011303 second(s), 3 queries , Gzip On, Redis On.
