查看: 2255|回复: 4
CYMCAP 8.1 Rev 3 Pro. Full Features
发表于 2023-8-9 19:41:52 | 显示全部楼层 |阅读模式
CYMCAP software  [color=var(--color-content-link)]Expertise To accurately calculate the capacity and heat of power transmission cables. The reports and results created by this software are very accurate and can help the team of engineers in designing and updating power transmission systems. With the help of accurate and practical results of this software The waste of financial and time resources has been minimized and the development team can develop its desired system in the fastest and most optimal possible way. In designing electronic components and systems, determining the resistance and load tolerance level of cables is very import ant and can increase the life of the device. With the help of this software, engineers are able to estimate the maximum load bearing of a cable and prevent its premature decay and failure.
CYMCAP software uses global and valid standards and standards to assess and rank the stability of cables and heat atonement. This software is supervised by the Canadian Electricity Association and by Hydro One، McMaster University of Canada and Cyme International are designed and developed to meet the latest international standards and standards. In addition to the core of the software, there are a number of additional modules that increase the software's capabilities and the possibility of modeling various electrical installations, especially non-standard and special facilities Provides.
CYMCAP software features:
  • Use of widely used software techniques based on Neher-McGrath and IEC-60287 <TAG1 methods>
  • Full compliance with North American laws and guidelines such as IEC 60287, IEC 60228, IEC 60853 and…
  • Fully visual interface and providing graphic mod els with high currents from different cables
  • Supports various types of power cables such as single-core, three-core, tagged Cable, pipe-type, submarine, sheathed, armored and …
  • Supports various methods of installing and setting up power cables such as direct burial of cables under the soil, thermal backfill, construction of underground ducts, duct bank, underground power grids and …
  • Ability to use and load independent and separate libraries and databases
  • Modeling different heat dissipation systems such as heat sinks and…
  • Ability to model different types of cables in one facility piece
  • Modeling non-temperature areas (Non-isothermal earth surface modeling )
  • Fully standard cycle loading patterns (Cylic loading patterns)
  • Ability to model different cables in one operational phase
For more information about CYMCAP 8.1 Rev 3, please contact   fast.forever24@gmail.com
发表于 2023-8-31 22:08:46 | 显示全部楼层
如何下载呢
发表于 2023-9-3 22:44:20 | 显示全部楼层
有需要联系 1400155802@qq.com
发表于 2023-11-14 21:03:00 | 显示全部楼层
有软件还不会用,希望一起交流学习。577007217@qq.com
发表于 2023-11-14 21:13:00 | 显示全部楼层
Thanks
GMT+8, 2025-12-26 11:00 , Processed in 0.015708 second(s), 5 queries , Gzip On, Redis On.
