查看: 2233|回复: 4
[求助] dc_shell 执行link后, Can't read in the DB file
发表于 2023-8-8 21:06:57 | 显示全部楼层 |阅读模式
dc_shell 执行link后,提示Can't read in the DB file,不知道该怎么解决,请各位大侠帮忙解答下
具体提示:
Loading db file '/home/projects/dc/lib/SP55NLLD2RNP_OV3_V0p5_ff_V1p32_0C.db'
Error: Can't read in the DB file 'SP55NLLD2RNP_OV3_V0p5_ff_V1p32_0C.db'.
        File 'SP55NLLD2RNP_OV3_V0p5_ff_V1p32_0C.db' is created using program version 'K-2015.06-SP1'
        which is newer than 'H-2013.03-SP1'. (UID-403)
Error: Could not read in the DB file '/home/projects/dc/lib/SP55NLLD2RNP_OV3_V0p5_ff_V1p32_0C.db'.
Loading db file '/home/projects/dc/lib/SP55NLLD2RNP_OV3_V0p5_tt_V1p2_25C.db'
Error: Can't read in the DB file 'SP55NLLD2RNP_OV3_V0p5_tt_V1p2_25C.db'.
        File 'SP55NLLD2RNP_OV3_V0p5_tt_V1p2_25C.db' is created using program version 'K-2015.06-SP1'
Error: Could not read in the DB file '/home/projects/dc/lib/SP55NLLD2RNP_OV3_V0p5_tt_V1p2_25C.db'.
发表于 2023-8-8 21:37:36 | 显示全部楼层
难道看不懂英文?
不是写得很明白吗
回复 支持 0 反对 1
发表于 2023-8-8 21:38:37 | 显示全部楼层
换一个高版本的dc_shell就可以了,比K-2015.06-SP1高就行
 楼主| 发表于 2023-8-8 21:48:28 | 显示全部楼层
解决了,需要转换下,版本太高了
发表于 2023-10-24 17:42:11 | 显示全部楼层
DB文件产生的软件版本和DC软件版本不一样  DB更新一些
GMT+8, 2025-12-23 03:50 , Processed in 0.014790 second(s), 4 queries , Gzip On, Redis On.
