查看: 2899|回复: 12
[求助] 请教一下大佬们 为什么附加代码生成的pcell 导出gds会报错
发表于 2023-7-24 10:20:21 | 显示全部楼层 |阅读模式
抱歉没注意到下载要积分 下面时源代码
procedure(back1()
     if(cdfid~>dum_l~>display=="nil"
       then
         cdfid~>dum_l~>value=cdfid~>L~>value
       else
       if(atoi(cdfid~>finger~>value)<4
        cdfid~>finger~>value="4"
       cdfid~>dum_l~>display=sprintf(nil,"%N" cdfid~>dum_t~>value)
       cdfid~>widthq~>display=sprintf(nil,"%N" cdfid~>dum_t~>value)
pcDefinePCell(
list( ddGetObj("pecll_tsmc") "NOS_CHAFEN" "layout"
) ; end of list for first argument
    (width string "1u" )
    (L string "0.8u")
    (finger string "6" )
    (dummy string "1" )
    (dum_l string "0.8u")
    (width string "1u")
    (dum_t boolean nil)
) ; end of pcell parameters
  let(() ; no local variables in this example
     display1=sprintf(nil,"%N" dum_t)
  if(cdfGetBaseCellCDF(ddGetObj("pecll_tsmc" "NOS_CHAFEN"))
   then
    cdfDeleteCDF(cdfid)
    cdfid=cdfCreateBaseCellCDF(ddGetObj("pecll_tsmc" "NOS_CHAFEN"))
   else
    cdfid=cdfCreateBaseCellCDF(ddGetObj("pecll_tsmc" "NOS_CHAFEN" ))
  cdfCreateParam(cdfid
    ?name "width"
    ?prompt "width"
    ?type "string"
    ?defValue "1u"
    ?display "t"
    ?storeDefault "yes"
    ?callback "back1()"
    ?name "L"
    ?prompt "L"
    ?type "string"
    ?defValue "0.8u"
    ?display "t"
    ?storeDefault "yes"
    ?callback "back1()"
    ?name "finger"
    ?prompt "finger"
    ?type "string"
    ?defValue "10"
    ?display "t"
    ?storeDefault "yes"
    ?callback "back1()"
    ?name "dummy"
    ?prompt "dummy"
    ?type "string"
    ?defValue "1"
    ?display "t"
    ?storeDefault "yes"
    ?callback "back1()"
    ?name "dum_t"
    ?prompt "dum_t"
    ?type "boolean"
    ?display "t"
    ?storeDefault "yes"
    ?callback "back1()"
    ?name "dum_l"
    ?prompt "dum_l"
    ?type "string"
    ?defValue "0.8u"
    ?display display1
    ?storeDefault "yes"
     cv=pcCellView
     layout=dbOpenCellViewByType("tsmc18rf" "nmos3vdnw" "layout")
;--------------------Create int1 and dummy----------------------
     int1_dum_r=dbCreateParamInst(cv layout nil list(0 0) "R0" 1
       list(
          list("w" "string" width)
          list("l" "string" dum_l)
          list("fingers" "string" dummy)
     int1=dbCreateParamInst(cv layout nil list(atof(dum_l)*atof(dummy)+atof(dummy)*0.54 0) "R0" 1
       list(
          list("l" "string" L)
          list("fingers" "string" finger)
      int1_dum_l=dbCreateParamInst(cv layout nil list(atof(int1_dum_r~>l)*atof(int1_dum_r~>fingers)+atof(int1_dum_r~>fingers)*0.54+atof(int1~>l)*atof(int1~>fingers)+atof(int1~>fingers)*0.54 0) "R0" 1
       list(
   if(atof(int1~>w)>=220.0
    then
     w1=atof(int1~>w)/1000
    else
     w1=atof(int1~>w)
   if(atof(int1~>l)>=220.0
    then
     l1=atof(int1~>l)/1000
    else
     l1=atof(int1~>l)
   space=w1+1.55
;--------------------Create int2 and dummy----------------------
     int2_dum_r=dbCreateParamInst(cv layout nil list(0 space) "R0" 1
       list(
     int2=dbCreateParamInst(cv layout nil list(atof(int2_dum_r~>l)*atof(int2_dum_r~>fingers)+atof(int2_dum_r~>fingers)*0.54 space) "R0" 1
       list(
     int2_dum_l=dbCreateParamInst(cv layout nil list(atof(int2_dum_r~>l)*atof(int2_dum_r~>fingers)+atof(int2_dum_r~>fingers)*0.54+atof(int2~>l)*atof(int2~>fingers)+atof(int2~>fingers)*0.54 space) "R0" 1
       list(
) ; end of pcDefinePCell
PCELL.txt
4.06 KB, 下载次数: 2 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2023-7-25 10:22:01 | 显示全部楼层
自己顶一下
发表于 2023-7-26 23:02:50 | 显示全部楼层
你把 cdf 函数要放在 pcell 代码外面试一下,我记得 cdf 函数不能放在 pcDefinePCell 里面的
 楼主| 发表于 2023-7-27 14:44:57 | 显示全部楼层
z10s113 发表于 2023-7-26 23:02
你把 cdf 函数要放在 pcell 代码外面试一下,我记得 cdf 函数不能放在 pcDefinePCell 里面的 ...
这样子写好像并不影响导出GDS ,但是如果我把原来的cdfid删掉然后创建新的cdfid 就会报错
发表于 2023-7-27 22:31:31 | 显示全部楼层
你试一下这样写可不可以
pcDefinePCell(
  list(ddGetObj("test") "ask" "layout" )
    (layer string "M1")
    (w float 3.0)
    (l float 6.0)
  let(()
    rodCreateRect(
      ?cvId pcCellView
      ?layer list(layer "drawing")
      ?width w
      ?length l
let((cellId cdfId)
  cellId=ddGetObj("test" "ask")
  cdfId=cdfGetBaseCellCDF(cellId)
  when(cdfId cdfDeleteCDF(cdfId) )
  cdfId=cdfCreateBaseCellCDF(cellId)
  cdfCreateParam(cdfId
    ?name "layer"
    ?type "radio"
    ?prompt "layer"
    ?defValue "M1"
    ?choices list("M1" "M2")
    ?name "w"
    ?type "float"
    ?prompt "width"
    ?defValue 1.0
    ?name "l"
    ?type "float"
    ?prompt "length"
    ?defValue 1.0
  cdfSaveCDF(cdfId)
 楼主| 发表于 2023-7-28 09:44:29 | 显示全部楼层
z10s113 发表于 2023-7-27 22:31
你试一下这样写可不可以
pcDefinePCell(
执行出来是这个样子的 只执行了上面的let块中的代码 下方let块中的代码并没有执行  我更改了pcdefinepcel这个函数的括号 让他把下方let块也包含进去 也没有反应。 我把下面let块写为函数进行调用也不行
发表于 2023-7-28 20:32:07 | 显示全部楼层
我的结果是这样的,下面 let 不要放在 pcdefinepcell 里面,不然不能出 gds
 楼主| 发表于 2023-7-31 14:52:04 | 显示全部楼层
但是这样的话 就不能实现复杂的pcell了
发表于 2023-8-1 22:19:00 | 显示全部楼层
可以啊,只是把 cdf 拿出来而已,还是存在的
 楼主| 发表于 2023-8-2 14:44:32 | 显示全部楼层
我再去研究一下 谢谢了大佬
GMT+8, 2025-12-23 08:52 , Processed in 0.029189 second(s), 4 queries , Gzip On, Redis On.
