查看: 2042|回复: 5
[讨论] PLL中的PFD设计
发表于 2023-7-16 16:45:31 | 显示全部楼层 |阅读模式
想请问大佬们,为什么很多PFD的输入时钟信号要通过偶数个反相器后再输入到D触发器,比如下图输入的时钟信号通过18个反相器到D触发器,这是基于什么考虑的?
 楼主| 发表于 2023-7-16 16:46:30 | 显示全部楼层
顶,求有大佬解答
发表于 2023-7-16 16:58:41 | 显示全部楼层
蹲。不过可以去掉反相器链试试有啥变化,我之前整体环路仿真时PFD中不加反相器链,直流点无法建立,仿真会报错。
 楼主| 发表于 2023-7-16 17:16:37 | 显示全部楼层
cmkong 发表于 2023-7-16 16:58
蹲。不过可以去掉反相器链试试有啥变化,我之前整体环路仿真时PFD中不加反相器链,直流点无法建立,仿真会 ...
我试过了,可以仿真
发表于 2023-7-16 17:58:30 | 显示全部楼层
usually ground is much stronger power supply, and falling edge is sharper, sharper edge -> less impact of noise which is present on power rail at moment of PFD is triggered. FB divider and input ref signals have "risings logic". for rising to falling logic conversion you need odd number of inverters for ref/fb signals before PFD.
发表于 2023-7-18 16:13:13 | 显示全部楼层
外部参考时钟给的信号是正弦波,需要转变为方波
GMT+8, 2025-9-12 21:23 , Processed in 0.015487 second(s), 4 queries , Gzip On, Redis On.
