查看: 2237|回复: 4
[求助] 请问各位大佬,这个电路有啥用?
发表于 2023-7-14 17:50:06 | 显示全部楼层 |阅读模式
是因为clk0_p, clk0_m的驱动能力不同,这样做是为了同步驱动能力吗?
发表于 2023-7-14 23:00:56 来自手机 | 显示全部楼层
是不是平衡上升下降沿?仿真看看
发表于 2023-7-14 23:01:54 来自手机 | 显示全部楼层
或者是占空比
发表于 2023-7-15 10:40:30 | 显示全部楼层
We call this has deskew circuit to make differential crossing at the center. To reduce offest between differential clocks.
 楼主| 发表于 2023-8-18 16:22:05 | 显示全部楼层
gubels 发表于 2023-7-15 10:40
We call this has deskew circuit to make differential crossing at the center. To reduce offest betwee ...
谢谢大神
GMT+8, 2025-12-4 12:31 , Processed in 0.015495 second(s), 5 queries , Gzip On, Redis On.
