如图,想知道输出的三个端口分别怎么读出数据?
附上Veriloga 代码
- `include "discipline.h"
- `include"constants.h"
- // $Date: 1997/08/28 05:53:32 $
- // $Revision: 1.1 $
- // Based on the OVI Verilog-A Language Reference Manual, version 1.0 1996
- `define PI 3.14159265358979323846264338327950288419716939937511
- `define ABSTOL_TIME 1e-12
- // power_meter
- // - Power meter
- // iin: input for current passing through the meter [V,A]
- // vp_iout: positive voltage sending terminal and output for current
- // passing through the meter [V,A]
- // vn: negative voltage sensing terminal [V,A]
- // pout: measured impedance converted to a voltage [V]
- // va_out: measured apparent power [W]
- // pf_out: measured power factor []
- // INSTANCE parameters
- // tstart = time to wait before starting measurement [s]
- // bw = bw of rms filters (a first order filter) [Hz]
- // log_to_file = whether to log the results to a file; yes or no []
- // filename = The name of the file in which the results are logged []
- // MODEL parameters
- // {none}
- // In order to measure the power being dissipated in a 2 port device,
- // this meter should be placed in the netlist so that the current flowing
- // into the device passes between 'iin' and 'vp_iout' first,
- // that 'vp_iout' is connected to the positive terminal of the device and
- // that 'vn' is connected to the negative terminal of the device.
- // The measured power is the average over time of the product of the voltage
- // across and the current through the device. This average is calculated by
- // integrating the VI product and dividing by time and passing the result
- // through a first order filter with bandwidth 'bw'.
- // The apparent power is calculated by finding the rms values of the current
- // and voltage first and filtering them with a first order filter of
- // bandwidth, 'bw'. The apparent power is the product of the voltage and
- // current rms values.
- // The purpose of the filtering is to remove ripple.
- // It is recommended that the 'bw' be set to a low value in order to
- // produce accurate measurements and that at least 10 input ac cycles be
- // allowed before the power_meter is considered settled. Also allow time
- // for the filters to settle.
- // This meter requires accurate integration so it is desirable that the
- // integration method is set to 'gear2only' in the netlist
- nature P_Power
- abstol = 1n;
- huge = 100M;
- units = "Watts";
- access = Pow;
- endnature
- nature PowerFactor
- abstol = 1m;
- units = "{none}";
- huge = 100M;
- access = PF;
- endnature
- discipline power_current
- potential P_Power;
- flow Current;
- enddiscipline
- discipline power_factor_current
- potential PowerFactor;
- flow Current;
- enddiscipline
- (* instrument_module *)
- module power_meter(iin,vp_iout,vn,pout, va_out, pf_out);
- electrical iin, vp_iout, vn;
- power_current pout;
- power_current va_out;
- power_factor_current pf_out;
- parameter real tstart = 0 from [0:inf);
- parameter real bw = 10 from (0:inf);
- parameter integer log_to_file = 0;
- electrical v_ifilt1, v_ifilt2;
- electrical v_vfilt1, v_vfilt2;
- electrical v_pfilt1, v_pfilt2;
- electrical vgnd;
- svcvs #(.poles({-2*`PI*bw,0}) ) irms_filter (v_ifilt2,vgnd,v_ifilt1,vgnd);
- svcvs #(.poles({-2*`PI*bw,0}) ) vrms_filter (v_vfilt2,vgnd,v_vfilt1,vgnd);
- svcvs #(.poles({-2*`PI*bw,0}) ) power_filter (v_pfilt2,vgnd,v_pfilt1,vgnd);
- integer out_file;
- real temp_var;
- real vin_val;
- real iin_val;
- real v_vfilt1_val;
- real v_ifilt1_val;
- real v_pfilt1_val;
- real irms;
- real vrms;
- real integ_vin_sqd; // Need to integrate squares of vin,iin because
- real integ_iin_sqd; // impedance measurement is based on rms values
- real integ_iin_vin; // Need this to calculate real power
- real pout_val; // measured real power
- real va_out_val; // measured apparent power
- real pf_out_val; // measured power factor angle
- real input_expr;
- analog begin
- @ ( initial_step ) begin
- if (log_to_file) begin
- out_file = $fopen( "%C:r.dat" );
- $fstrobe(out_file,"# Generated by Spectre from module `%M'");
- end
- end
- V(vgnd) <+ 0;
- // so that device is not intrusive
- V(iin,vp_iout) <+ 0;
- vin_val = V(vp_iout,vn);
- iin_val = I(iin,vp_iout);
- // vrms calculation
- if ($abstime > tstart)
- input_expr = vin_val*vin_val;
- else
- input_expr = 0;
- integ_vin_sqd = idt(input_expr,0);
- if ($abstime > tstart) begin
- if (($abstime-tstart) > `ABSTOL_TIME) begin // to avoid div by zero error
- v_vfilt1_val = sqrt(integ_vin_sqd/($abstime-tstart));
- end
- end else begin
- v_vfilt1_val = 0;
- end
- V(v_vfilt1) <+ v_vfilt1_val;
- vrms = V(v_vfilt2);
- // irms calculation
- input_expr = iin_val*iin_val;
- else
- input_expr = 0.0;
- integ_iin_sqd = idt(input_expr,0 );
- v_ifilt1_val = sqrt(integ_iin_sqd/($abstime-tstart));
- end
- end else begin
- v_ifilt1_val = 0;
- end
- V(v_ifilt1) <+ v_ifilt1_val;
- irms = V(v_ifilt2);
- // apparent power calculation
- va_out_val = irms*vrms;
- // real power calculation
- input_expr = iin_val*vin_val;
- else
- input_expr = 0;
- integ_iin_vin = idt(input_expr,0);
- if (($abstime- tstart) > `ABSTOL_TIME) begin // to avoid div by zero error
- v_pfilt1_val = integ_iin_vin/($abstime-tstart);
- end
- end else begin
- v_ifilt1_val = 0;
- end
- V(v_pfilt1) <+ v_pfilt1_val;
- pout_val = V(v_pfilt2);
- // pf_out_val calculation
- if ( va_out_val > pout.potential.abstol ) begin
- temp_var = pout_val/va_out_val;
- temp_var = max(temp_var,-1);
- temp_var = min(temp_var,1);
- pf_out_val = temp_var;
- end else begin
- pf_out_val = 0;
- end
- $fstrobe(out_file, "%-.10g\t%-.10g\t%-.10g\t%-f",
- $abstime, pout_val, va_out_val, pf_out_val);
- end
- Pow(pout) <+ pout_val;
- Pow(va_out) <+ va_out_val;
- PF(pf_out) <+ pf_out_val;
- @ ( final_step ) begin
- if (log_to_file) $fclose(out_file);
- end
- end
- endmodule
复制代码
