查看: 1821|回复: 1
[求助] matlab硬件回环实验FIL遇到的问题
发表于 2023-7-4 17:21:31 | 显示全部楼层 |阅读模式
Info (213045): Using programming cable "DE-SoC [USB-1]"
Info (213011): Using programming file C:/Users/Administrator/Documents/MATLAB/Examples/R2023a/hdlverifier/VerifyPIDFIL/Controller_fil/Controller_fil.sof with checksum 0x0135CE09 for device 5CSEMA5F31@1
Info (209060): Started Programmer operation at Tue Jul 04 17:17:49 2023
Error (209015): Can't configure device. Expected JTAG ID code 0x02D120DD for device 1, but found JTAG ID code 0x4BA00477. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Jul 04 17:17:50 2023
Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings
    Error: Peak virtual memory: 4435 megabytes
    Error: Processing ended: Tue Jul 04 17:17:50 2023
    Error: Elapsed time: 00:00:02
    Error: Total CPU time (on all processors): 00:00:01
我在simulink中最后烧录进fpga中遇到了这样的报错,但是我的开发板上芯片配置是和我实际所使用的芯片的型号一样。不知道问题出在哪里
求各位大佬看看
 楼主| 发表于 2023-8-2 15:52:44 | 显示全部楼层
已经解决
GMT+8, 2025-12-30 00:18 , Processed in 0.014771 second(s), 4 queries , Gzip On, Redis On.
