查看: 1888|回复: 2
[资料] zobovision(深圳)_heif_heic_encoder_FPGA_ASIC_IP
发表于 2023-7-3 14:18:44 | 显示全部楼层 |阅读模式
zobovision
HEIF/heic image Encoder FPGA/ASIC IP
  HEIF/heic Encoder, HEVC/H.265 Standard
  RTL or Netlist authorization
  FPGA or ASIC/SOC IP
  Ultra-large image size, up to 32k*32k
  yuv420/8bit(Default), yuv422/yuv444/10bit (Optional)
  Zero-latency bitstream output by ultra fast real-time CABAC encoding
  Constant encoding speed, linear with image size
  Same image size, Same encoding cycle, independent of quality settings
  External memory free, No DDRx required
  Standalone, No Processors requried
  1080p@60fps/1ipor 4K@15fps/1ip capability on FPGA platform
  <10% compression ratios losses compare with the bestest software encoder
  logic resource: ~100K Luts (xilinx FPGA)
  fmax: ~280Mhz (xilinx FPGA)
zobovision(深圳)_heif_heic_encoder_FPGA_ASIC_IP.pdf
362.76 KB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2023-9-18 08:53:45 | 显示全部楼层
thanks
发表于 2024-10-30 09:29:50 | 显示全部楼层
Thanks
GMT+8, 2025-12-14 14:54 , Processed in 0.018302 second(s), 7 queries , Gzip On, Redis On.
