查看: 1760|回复: 2
[讨论] 专利dual gate oxide 提到 3类 mos 疑问
发表于 2023-6-16 13:28:20 | 显示全部楼层 |阅读模式
专利US20100308415A1 提到 3类 mos 疑问
dual gate oxide CMOS technology providingthree types of transistor; a thin oxide device, a thick oxide device, and athin oxide device using the implant type of the thick oxide device for providingimproved analogue performance.
dual gate oxide  提到 可 3类 mos
这是指甚?
thingate thick gate 低压mospower 工艺的高压mos ??
发表于 2023-6-16 13:43:57 | 显示全部楼层
thin gate + LV drain/source implants
thick gate + HV implants
thin gate + HV implants
 楼主| 发表于 2023-6-19 08:30:52 | 显示全部楼层
thank you .
thin gate + HV implants  =>  vds source/drain 耐高压 是多高?   12v  or 24v ?
工艺 low volt mos 工艺 不是有 over driver ?  是这一类吗? 5V od 6V
高压工艺有种hv gate mv mos LHL , MHM
LHL =  hvthick gate + LV drain/source
MHM = hv thick gate + Hv drain /source
GMT+8, 2025-10-24 09:23 , Processed in 0.014211 second(s), 3 queries , Gzip On, Redis On.
