查看: 2942|回复: 2
[求助] cadence使用
发表于 2023-5-11 17:02:07 | 显示全部楼层 |阅读模式
CDF里面的器件参数显示不让修改怎么办?保存修改的时候显示错误
*ERROR* The 'Default Value' is not specified for the following component parameter(s):  degradation
        'Default Value' is a mandatory field for component parameters.
         These component parameters will not be added to the CDF.
发表于 2023-12-18 10:31:49 | 显示全部楼层
楼主解决了吗
发表于 2024-11-21 18:46:23 | 显示全部楼层
楼主解决了吗?
GMT+8, 2025-12-15 06:06 , Processed in 0.014836 second(s), 3 queries , Gzip On, Redis On.
