查看: 2112|回复: 1
[求助] LVS验证、器件定义类
发表于 2023-3-27 15:25:38 | 显示全部楼层 |阅读模式
LVS 验证被中断,Location Errors
报出的错是 LOC2: A layer operation which is not assigned as part of a layer definition wasencountered outside of the brackets delimiting the body of a rule checkstatement. The primary keyword of the erroneous operation appears in the errormessage。
this unassigned layer operation must be insaide of a rulecheck statement :area.
哪位大神能告诉我怎么解决吗?
 楼主| 发表于 2023-4-18 09:34:41 | 显示全部楼层
问题已解决,降了calibre版本后没有出错。
GMT+8, 2025-12-20 19:59 , Processed in 0.016773 second(s), 4 queries , Gzip On, Redis On.
