查看: 4022|回复: 5
[求助] AMS仿真error求助
发表于 2023-3-7 17:19:05 | 显示全部楼层 |阅读模式
悬赏30资产未解决
AMS仿真遇到error:ERROR (ADE-5021): The variable 'envOpts check_simulator' is not declared for tool 'ams3'.This error appears when
        environment variables, which are no longer supported are still being set either
        through ADE state files or through .cdsinit/.cdsenv files. Ignore this message
        if the listed variable is not required.
然后tran仿真到8.5us就自动停止。log file 见下图
谢谢解答~
 楼主| 发表于 2023-3-8 09:11:08 | 显示全部楼层
顶一下
 楼主| 发表于 2023-3-12 22:22:55 | 显示全部楼层
顶一下
 楼主| 发表于 2023-3-14 14:17:41 | 显示全部楼层
顶一下
 楼主| 发表于 2023-3-15 14:45:37 | 显示全部楼层
顶一下
发表于 2024-7-4 11:17:01 | 显示全部楼层
楼主解决了没 我也遇到了这个问题
GMT+8, 2025-12-24 21:23 , Processed in 0.028663 second(s), 3 queries , Gzip On, Redis On.
