楼主: Listen.
[求助]virtuoso:CIW窗口标题栏不显示
 楼主| 发表于 2023-2-20 18:16:52 | 显示全部楼层
amodaman 发表于 2023-2-20 17:46
确实是这个文件,你要改的是font color吧,foreground和background之类的
大佬,我把这个文件的全粘帖了,您给看看,要怎么改 太不容易了,终于看到希望点了
! ************.Xdefaults****************
! The following are examples of Resources that
! the user may wish to set.
! The "!" character is a comment.  To activate a resource,
! you can remove the ! character at the beginning of a line.
! A lot of .Xdefaults files use "#" as the comment character,
! this should be avoided.
! Remember that you need to run the "xrdb" program to
! have a resource take effect once the X server has been started.
! You can invoke it as "xrdb ~/.Xdefaults"
! xrdb reads the new .Xdefaults file into the server.
! For Opus, beware of loose bindings (eg "Opus*resource:") as they may
! cause a conflict with some things that you set in Skill.
! All Opus resources are Opus.<resource>:
! * These resources set the default position of the CIW. *
!Opus.x:             !!!(screen_width - Opus.width)/2
!Opus.y:             0
!Opus.width:         725
!Opus.height:        130
! *** Or you can use the geometry specification
! *** if you don't want to use the x,y,width,height
! *** resources independently
!Opus.geometry:
! * These resources allow you to set the fonts *
Opus.labelFont:     -*-helvetica-bold-r-*-*-12-*
Opus.textFont:      -*-courier-medium-r-*-*-12-*
! * This resource lets you specify which text editor *
! * you want to use.                                 *
!Opus.textEditor:
! * This resource lets you set the     *
! * colors used by the user interface. *
!Opus.foreground:               #800000
!Opus.background:               #e0e0e0
!Opus.borderColor:              #0000c0
!Opus.recessColor:              #bfbfbf
!Opus.activeBannerColor:        #bdcccc
!Opus.inactiveBannerColor:      #cccccc
!Opus.textColor:                #333333
!Opus.attentionTextColor:       #333333
!Opus.flashColor:               #ff00ff
!Opus.topShadowColor:           #ffffff
!Opus.bottomShadowColor:        #999999
!Opus.buttonColor:              #800000
!Opus.editorBackground:         #000000
! * These resources allow you to specify the default *
! * positions for forms.                             *
!Opus.formPlacement: one of  top,bottom,left,right, or center
!Opus.formRelativeTo: one of screen,currentWindow,  or CIW
!Opus.optionFormPlacement: one of top,bottom,left,irhgt or center
!Opus.optionFormRelativeTo: one of screen,currentWindow, or CIW
! ** END OPUS RESOURCES
! Here are some defaults for the xterm
XTerm*foreground:        yellow
XTerm*background:        darkslategrey
XTerm*border:                turquoise
XTerm*cursorColor:        yellow
XTerm*sunFunctionKeys:        True
XTerm*jumpScroll:        True
XTerm*pointerColor:        red
XTerm*scrollBar:        True
XTerm*saveLines:        120
XTerm*scrollKey:        True
XTerm*font:                9x15
! SAMPLE .Xdefaults RESOURCE SPECIFICATIONS FOR MWM
! component appearance resources
Mwm*clientAutoPlace:                False
Mwm*colormapFocusPolicy:        explicit
Mwm*keyboardFocusPolicy:        pointer
Mwm*InteractivePlacement:       False
Mwm*menu*background:                CadetBlue
Mwm*menu*foreground:                Yellow
Mwm*foreground:                        white
Mwm*background:                        SteelBlue
Mwm*fontList:                        9x15
Mwm*backgroundTile:                background
Mwm*activeBackground:                CadetBlue
Mwm*transientDecoration:         titlebar + resize - menu
Mwm*buttonBindings:                SampleButtonBindings
Mwm*windowMenu:                        SampleWindowMenu
Mwm*focusAutoRaise:                False
Mwm*enforceKeyFocus:                False
Mwm*saveUnder:                        True
Mwm*useIconBox:                        False
Mwm*frameBorderWidth:                3
Mwm*resizeBorderWidth:                5
Mwm*cleanText:                  True
! Following are the .Xdefaults additions recommended for
! FrameMaker 2.1X:
! Frame 2.1X Specific defaults
Maker.doubleClickTenths:        10
Maker.useBackingStore:          True
Maker.cmdEscape:                True
Maker.autoBackupOnSave:         True
Maker.autoSave:                 True
Maker.autoSaveTime:             5
Maker.autoSaveIdleTime:         10
Maker.greekSize:                7
Maker.foreground:               white
Maker.background:               turquoise
Maker.console:                  True
Maker.noViewerFile:             True
Maker.colorDocs:                True
Maker.colorImages:                True
Maker.olwmClickType:                 False
 楼主| 发表于 2023-2-20 18:24:52 | 显示全部楼层
我改了
Mwm*foreground:  black(原white)
Maker.foreground:  black(原white)
保存
然后xrdb
还是不行,啥反应都没,真要哭了
发表于 2023-2-20 18:38:36 | 显示全部楼层
改Mwm和Maker是没用的,Mwm是很古老的一款UNIX上的window manager,Maker是指Frame Maker,拿来产生PDF文件的。要改的还是Opus的资源,不是其他的。
 楼主| 发表于 2023-2-21 10:35:58 | 显示全部楼层
amodaman 发表于 2023-2-20 18:38
改Mwm和Maker是没用的,Mwm是很古老的一款UNIX上的window manager,Maker是指Frame Maker,拿来产生PDF文件 ...
大佬,首先确定几个事
1.文件确实是这个文件,因为,我修改了一下的2个值,确实位置会有变动
Opus.width:         725
Opus.height:        130
2.根据大佬的意思,我将这些下面后面的值都改成#cccccc,运行xrdb后,virtuoso感觉没有任何颜色变化
3.这个如果要修改怎么修改。
总结:文件有用,除了大小改了会有体现,其他感觉改了和没改没区别。。。咋整
 楼主| 发表于 2023-2-28 09:06:48 | 显示全部楼层
大佬,我发现一个事,我用虚拟机,第一次安装后打开,是会显示标题栏的,没有任何问题,但是重启后,就不显示了,卸载重装都没有效果,只能快照还原+重新安装,那就是说,重启后是串改了什么文件或者原本缓存的文件被清除的感觉
另外,如果是font问题,那刚安装完,应该也不会显示才对。有没有什么看法?
发表于 2023-2-28 13:12:18 | 显示全部楼层
Listen. 发表于 2023-2-28 09:06
大佬,我发现一个事,我用虚拟机,第一次安装后打开,是会显示标题栏的,没有任何问题,但是重启后,就不 ...
其实根源在于Centos7操作系统,而我不用这个操作系统,复现不了你的问题。Cadence建议的是RHEL,现在Cadence最新版本是RHEL7.9可以兼容,所以挑一个RHEL6.9装上最安全,RHEL7.x对最近的几个Cadence版本都没问题。
 楼主| 发表于 2023-2-28 14:33:34 | 显示全部楼层
amodaman 发表于 2023-2-28 13:12
其实根源在于Centos7操作系统,而我不用这个操作系统,复现不了你的问题。Cadence建议的是RHEL,现在Cade ...
RHEL我也装了,还是一样,版本是RHEL7.6,IG617小版本700_base 和IC617.-64b,500.22,同样问题
发表于 2023-2-28 14:43:29 | 显示全部楼层
RHEL7.6也有同样的问题?不应该吧,那给我看一下你的.cdsinit文件做了什么事情
 楼主| 发表于 2023-2-28 14:59:24 | 显示全部楼层
cdsinit.zip (837 Bytes , 下载次数: 1 )
也没做什么啊。。。。
 楼主| 发表于 2023-3-1 09:12:32 | 显示全部楼层
我觉得和.csdinit没关系,我刚看了这个文件,里面写的是calibre,我为了测试,我连calibre都没装只装IC617,都不显示
GMT+8, 2025-12-4 06:35 , Processed in 0.019221 second(s), 4 queries , Gzip On, Redis On.
