楼主: jhliu99
Nonvatile Memory -Flash的可靠性如何评估
发表于 2008-11-3 09:37:58 | 显示全部楼层
TKS!!!!!!!!!!!!!!!
发表于 2008-11-8 12:11:51 | 显示全部楼层
Thanks1
发表于 2008-12-10 00:29:31 | 显示全部楼层
好东西哦,谢谢楼主
发表于 2009-1-9 13:26:09 | 显示全部楼层
Good!
发表于 2009-4-17 05:27:09 | 显示全部楼层
楼主是专门搞NVM的RELIABILIGY研究的吧
发表于 2009-4-29 21:52:00 | 显示全部楼层
TKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 楼主| 发表于 2009-5-24 08:27:21 | 显示全部楼层
再传一篇PPT
Modeling Flash Memories for IC Designs
Luca Larcher
Università di Modena e Reggio Emilia Reggio Emilia - Italy
luca.larcher@unimore.it
Modeling Flash Memories for IC Designs .pdf
677.58 KB, 下载次数: 30 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-5-24 08:31:11 | 显示全部楼层
This paper presents a survey of the principal architectures and
blocks building up a Flash memory, describing how these blocks
are designed and how their design has changed over the years to
satisfy the new specification requests. For example, the continuous
supply voltage reduction aimed at portable electronic solutions has
forced designers to find innovative design solutions. An overview
of the test modes developed for the Flash device not only to debug
the chip but also to try to improve reliability is given. Ad hoc test
modes are useful to deeply increase the analysis capability. Finally,
the test methodology for Flash memories, a challenge between the
test time reduction and better test coverage, is presented.
Keywords—Access time, automatic test equipment (ATE), boost,
charge pump, chip-scaled package (CSP), decoders, dual in-line
(DIL), direct memory access (DMA), drain stress, electrical stress,
erasable programmable ROM (EPROM), electrical wafer sort
(EWS), finite-state machine (FSM), Flash memory, Fourier transform,
gate stress, matrix organization, one-time programmable
(OTP), reference, sector, test modes, triple well, unerasable
programmable ROM (UPROM), voltage regulator.
0_An overview of flash architectural developments.pdf
693.3 KB, 下载次数: 28 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-5-24 08:35:38 | 显示全部楼层
ST 大牛Marco Pasotti写得flash design ppt
Non Volatile Memories Design
Marco Pasotti
STMicroelectronics
8 Marzo 2004
Universitá degli Studi di Modena
Outline
NOR Flash Memories
– Basics modes of operation
– Array architecture
– Design building blocks
– Read path
– Program path
– Erase path
– Multi level cell design
Embedded Flash Memories
NAND Flash Memories
0_good_ST_Marco_Passoti-Non-volatile Memories Design.pdf
839.44 KB, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-6-16 11:03:22 | 显示全部楼层
ding!!!!!!
GMT+8, 2025-12-20 06:20 , Processed in 0.021416 second(s), 4 queries , Gzip On, Redis On.
