楼主: netelf
怎么安装Redhawks2021R1.1啊
发表于 2023-1-19 21:45:58 | 显示全部楼层
netelf 发表于 2023-1-19 19:08
是不是这样的如果用的是bash,就只需要source一下setup.bash和setup.sh
但我弄完之后又出错误了。。。
这个是安装的之后cp -r 了原始目录吧 ?
老老实实
1.xz -d xxx.xz
2. tar xf xxx.tar
看目录管理不方便,就用
mv redhawk_xxx redhawk_yyy
发表于 2023-1-19 22:31:48 | 显示全部楼层
netelf 发表于 2023-1-19 19:56
我为啥redhawk之后就错误了啊
Since "/lib64/libGLU.so.1" must be in the OS installation path, it is necessary to understand that the package containing it is missing from the Ubuntu OS installation process.
Therefore, " libGLU.so" shared library is not a RedHawks application component.
You need to find library package which  has libGLU.so.1 using below command.
% yum whatprovides /lib64/libGLU.so.1
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-manager
server        5230/5230
mesa-libGLU-9.0.0-4.el7.x86_64 : Mesa libGLU library
Repo        : @anaconda/7.9
Matched from:
Filename    : /lib64/libGLU.so.1
So you need to install it.
-- Redhat, CentOS
case 1. find "mesa-libGLU-9.0.0-4.el7.x86_64.rpm" and install it by rpm command.
          % rpm -ivh mesa-libGLU-9.0.0-4.el7.x86_64.rpm
case 2. If it has dependency for "mesa-libGLU-9.0.0-4.el7.x86_64.rpm" , you need to install all the libraries dependent on this package, proceed with the installation as follows.
         % yum install mesa-libGLU-9.0.0-4.el7.x86_64
-- Package install on Ubuntu  ( Ref: https://zoomadmin.com/HowToInstall/UbuntuPackage/libglu1-mesa )
        % sudo apt-get install -y libglu1-mesa
 楼主| 发表于 2023-1-19 22:51:42 | 显示全部楼层
老老实实
不是不是,我是直接tar -xvf
发表于 2023-1-19 22:55:22 | 显示全部楼层
netelf 发表于 2023-1-19 22:51
不是不是,我是直接tar -xvf
这个看起来也没啥问题。。。OS是啥版本 ?
 楼主| 发表于 2023-1-19 23:07:20 | 显示全部楼层
就是centos
这是我加的bash里面的
发表于 2023-1-19 23:11:31 | 显示全部楼层
1. 就是centos , 具体啥版本? 2021 推荐用 7.x    cat /etc/redhat-release
2. license 貌似设错了, 一般是啥 xxx.dat xxx.lic
3. ansyscl 是个exe文件 binary的 , license 一般是 text 文件,asicII的 ~~~
 楼主| 发表于 2023-1-19 23:13:22 | 显示全部楼层
3. an ...
7.9的
 楼主| 发表于 2023-1-19 23:14:38 | 显示全部楼层
2. license 貌似设错了, 一 ...
我是从本贴链接里取的lic
发表于 2023-1-19 23:15:06 | 显示全部楼层
centOS 7.9 没问题的。。。
那前面的log 是少库了。。。弄个本地源,yum 装一下就行了。。。
发表于 2023-1-19 23:16:04 | 显示全部楼层
netelf 发表于 2023-1-19 23:14
我是从本贴链接里取的lic
用编辑工具vi打开看一下。ansyscl
GMT+8, 2025-12-27 02:16 , Processed in 0.020213 second(s), 5 queries , Gzip On, Redis On.
