楼主: netelf
怎么安装Redhawks2021R1.1啊
发表于 2023-1-15 15:03:16 | 显示全部楼层
% is for displaying a prompt
ex)
% ls -al
This means run "ls -al" linux command.
发表于 2023-1-15 15:10:44 | 显示全部楼层
ipex 发表于 2023-1-14 09:57
would you share the software and lic, thanks!
https://pan.baidu.com/s/19oay2_fhxw2wLIRzGMPoGg?pwd=51ny
51ny
Looking for a way to attach a file...  for
 楼主| 发表于 2023-1-15 23:04:50 | 显示全部楼层
ex)
ubuntu咋设置啊
发表于 2023-1-16 08:34:15 | 显示全部楼层
netelf 发表于 2023-1-15 23:04
ubuntu咋设置啊
우분투와 레드햇에서 설정하는 방법에는 차이가 없습니다.
 楼主| 发表于 2023-1-16 16:20:41 | 显示全部楼层
可是setenv这个命令在ubuntu运行不了啊,那个setup.csh里面会报错啊
发表于 2023-1-16 21:37:12 | 显示全部楼层
It's not an Ubuntu OS issue.
You can select csh from among csh , bash , tcsh ... etc. in the /etc/passwd file for the user account shell configuration.
If you wish to use a shell other than csh, you can use the shell's equivalent command.
     Search the keywords below on Google.
         setenv equivalent in bash
         setenv equivalent in ksh
To change the user shell, refer to the link below.
https://www.tecmint.com/change-a-users-default-shell-in-linux/
发表于 2023-1-16 22:12:26 | 显示全部楼层
csh
用户要切换成csh
发表于 2023-1-17 10:40:47 | 显示全部楼层
这种文件是使用tar打包后再压缩生成的。解压方法是:
1、xz -d **.tar.xz
2、tar -xvf **.tar
 楼主| 发表于 2023-1-19 19:08:30 | 显示全部楼层
voiluce 发表于 2023-1-16 22:12
csh
用户要切换成csh
是不是这样的如果用的是bash,就只需要source一下setup.bash和setup.sh
但我弄完之后又出错误了。。。
 楼主| 发表于 2023-1-19 19:56:22 | 显示全部楼层
joshua2784920 发表于 2023-1-14 09:34
In your home directory, insert following setup env in to .cshrc file like as below.
setenv APACHER ...
我为啥redhawk之后就错误了啊
GMT+8, 2025-12-15 20:48 , Processed in 0.022920 second(s), 3 queries , Gzip On, Redis On.
