查看: 2597|回复: 0
[其它] 英特尔开源用Dart语言进行芯片开发和验证的开发框架和验证框架
发表于 2022-12-27 01:06:17 | 显示全部楼层 |阅读模式
Rapid Open Hardware Development (ROHD) Framework
ROHD (pronounced like "road") is a framework for describing and verifying hardware in the Dart programming language. ROHD enables you to build and traverse a graph of connectivity between module objects using unrestricted software.
开源地址:
intel/rohd: The Rapid Open Hardware Development (ROHD) framework is a framework for describing and verifying hardware in the Dart programming language. ROHD enables you to build and traverse a graph of connectivity between module objects using unrestricted software. (github.com)
验证框架地址:
intel/rohd-vf: The ROHD Verification Framework is a hardware verification framework built upon ROHD for building testbenches. (github.com)
可直接编译使用的ROHD例子:
poorjobless/rohd-example (github.com)
使用方式:
1. 下载dart sdk并设置好环境变量
2. cd 到子例目录
3. 运行 ·dart run· 即可运行,运行后会生成systemverilog代码并进行仿真生成波形文件。也可将项目编译成exe或js文件方便分发。
如果需要编译成exe文件或js文件则 运行 ·dart compile exe 子例名称\bin\子例名称.dart· 则会生成exe可执行文件 运行 ·dart compile js 子例名称\bin\子例名称.dart· 则会生成js文件
例如:fir_filter
1. cd fir_filter
2. dart compile exe -o out\fir_filter.exe bin\fir_filter.dart 如果不加-o参数则编译后的文件默认在bin目录下,js则在项目根目录下。
红框的为编译运行后生成的文件,rtl.sv和waves.vcd为运行后生成的文件。
可直接编译使用的ROHD-VF例子:
poorjobless/rohd-vf_example (github.com)
使用方式:
2. 运行 ·dart run· 或 ·dart test·
P.S:这回连搞网页和app前端的都能搞芯片开发了
GMT+8, 2025-12-20 21:40 , Processed in 0.018154 second(s), 5 queries , Gzip On, Redis On.
