查看: 9804|回复: 38
C* P_V_S
发表于 2022-11-27 04:50:35 | 显示全部楼层 |阅读模式
Base + Hotfix for 191/201/211/221/222.
If someone needs to download version 191, check md5 carefully, specifically for hotfixes 19.14 and 19.15 (they have mismatched md5 for me).
This usually happens when they add a fix to an already existing release without notice. (just change a few numbers in the description). Some time ago I already encountered this - they posted two different versions of S_S_V 21.14 s108 and s111 (I noticed the changes after I rechecked that release) - the difference is one small fix (but at that moment I managed to download the full set of files for both versions ).
Here I think the case is similar, archives are newer, text documents/md5 are older.Re-downloading isn't possible because this version has been removed from the site. Also they remove version 201.
P_V_S_211
P_V_S_211
P_V_S_221
P_V_S_221
P_V_S_222
P_V_S_222
P_V_S.txt
90 Bytes, 下载次数: 372 , 下载积分: 资产 -2 信元, 下载支出 2 信元
售价: 2 信元资产  [记录]
pv1
发表于 2022-11-27 05:02:37 | 显示全部楼层
Thanks!
发表于 2022-11-27 06:43:08 | 显示全部楼层
Thanks!
发表于 2022-11-27 07:45:36 | 显示全部楼层
Thanks
发表于 2022-11-27 08:32:04 | 显示全部楼层
thanks
发表于 2022-11-27 08:36:50 | 显示全部楼层
thanks!!!!
发表于 2022-11-27 08:47:01 | 显示全部楼层
Thanks a lot for your sharing.
发表于 2022-11-27 09:13:12 | 显示全部楼层
Thank you very very very much.
发表于 2022-11-27 10:26:08 | 显示全部楼层
Thinks!!!
发表于 2022-11-27 10:44:57 | 显示全部楼层
This one is my call, really appreciate for your sharing, you are the best!
GMT+8, 2025-9-14 03:22 , Processed in 0.019208 second(s), 5 queries , Gzip On, Redis On.
