查看: 8480|回复: 41
[资料] Algorithms and Architectures for Cryptography and Source Coding in Non-Volatile Flash Memories @2021
发表于 2022-11-1 00:02:46 | 显示全部楼层 |阅读模式
In this work, we focus on the ECC systems, due to the similar security level promised with significantly smaller key lengths compared with RSA.  However, software implementations of ECC algorithms on flash memory controllers may result in unacceptable computational latency. To reduce the computational latency to an acceptable range of a few milliseconds, we present hardware architectures optimized for the ECC operations targeting a low area. We propose an ECC processor design for Gaussian integers that is a competitive solution for applications in resource-constrained embedded systems such as flash memory controllers.
Algorithms and Architectures for Cryptography and Source Coding in Non-Volatile .pdf (2.84 MB , 下载次数: 138 )
发表于 2022-11-1 08:22:38 | 显示全部楼层
good topic
3q for share~
发表于 2022-11-1 09:22:35 | 显示全部楼层
谢谢分享
发表于 2022-11-1 09:59:10 | 显示全部楼层
Thank you a lot for the sharing.
发表于 2022-11-1 10:02:17 | 显示全部楼层
多谢分享!
发表于 2022-11-1 12:28:42 | 显示全部楼层
谢谢分享!!
发表于 2022-11-1 20:54:36 | 显示全部楼层
good one
发表于 2022-11-1 21:40:03 | 显示全部楼层
kanaknaaa
发表于 2022-11-1 21:45:27 | 显示全部楼层
谢谢分享
发表于 2022-11-1 23:06:17 | 显示全部楼层
谢谢分享!
GMT+8, 2025-12-30 10:57 , Processed in 0.019800 second(s), 4 queries , Gzip On, Redis On.
