查看: 3177|回复: 2
[原创] virtuoso的layout导出gds文件
发表于 2022-10-31 10:12:04 | 显示全部楼层 |阅读模式
将virtuoso的layout导出为gds文件,导入到ADS中时,发生以下警告,导入无版图。
WARNING: (OASTRM-80011): The gds layer and gds purpose pair "31, 125" was not found in the layer map file. Data referencing this gds layer and gds purpose pair was ignored.
WARNING: (OASTRM-80011): The gds layer and gds purpose pair "123, 0" was not found in the layer map file. Data referencing this gds layer and gds purpose pair was ignored.
发表于 2023-9-19 22:00:58 | 显示全部楼层
您好,问题解决了么,我导入时也是有一层报这样的错误,但是layermap里是有对应的层的
 楼主| 发表于 2023-9-21 11:18:14 | 显示全部楼层
n4ked 发表于 2023-9-19 22:00
您好,问题解决了么,我导入时也是有一层报这样的错误,但是layermap里是有对应的层的 ...
只要不是重要的图层,警告可以不用管,不报错就行。
GMT+8, 2025-12-29 00:38 , Processed in 0.013051 second(s), 4 queries , Gzip On, Redis On.
