查看: 2816|回复: 4
dvt 2022的求助
发表于 2022-10-19 14:13:48 | 显示全部楼层 |阅读模式
大家有遇到这个问题吗?dvt帖子
[WARNING] Unable to find a working GTK and browser engine combination, using 'gtk2' (error E99__no_valid_config_found)
[WARNING] It means that this DVT distro flavor is not compatible with your OS, and crashes are likely to occur.
[WARNING] Possible fixes:
[WARNING]  - Install/Update WebKitGTK library in your OS
[WARNING]  - Download a DVT distro based on a different Eclipse version, currently you are using one based on Eclipse 4.19.0
JVM terminated. Exit code=13
求助解决办法
发表于 2022-10-24 11:10:13 | 显示全部楼层
修改 你自己 安装目录下 java 的属性,增加可执行。chmod +x /usr/dvte/dvt_kit-22.1.16-e419-lnx_64/jdk/bin/java
 楼主| 发表于 2022-10-25 19:30:42 | 显示全部楼层
navie 发表于 2022-10-24 11:10
修改 你自己 安装目录下 java 的属性,增加可执行。chmod +x /usr/dvte/dvt_kit-22.1.16-e419-lnx_64/jdk/b ...
还是不行
我把dvt_eclipse 下面所有的bin文件都设置成可执行,还是不行。
发表于 2023-7-30 11:08:34 | 显示全部楼层
赞,已解决
发表于 2024-1-5 11:49:07 | 显示全部楼层
楼主解决的吗?
GMT+8, 2025-12-26 06:57 , Processed in 0.016647 second(s), 5 queries , Gzip On, Redis On.
