查看: 3413|回复: 10
[求助] BCD工艺高压MOS管连接
发表于 2022-10-14 14:57:57 | 显示全部楼层 |阅读模式
X-FAB的XT018工艺高压MOS管的B端和HW端应该如何连接?
发表于 2022-10-14 16:19:45 | 显示全部楼层
G is the gate voltage,
S is the Source electrode
D is the Drain  one
when Vgs is greater than Vt, it is turned on
Vgs below 0 turn off.
Be aware the spice model only represent the typ. threshold voltage.  Because the Xfab has different manufacture processes in their foundries (not identical as Intel or ST did) - Your HV MOS is manufactured in Malaysia not in Erfurt Germany.  The technology is premature and cannot withstand high power, getting hot once turned on (cost is high as well).  Vt is reduced with temperature, when the HVMOS is hot, Vth falls below 0.95V
发表于 2022-10-14 20:30:06 | 显示全部楼层
D is the Drain  one
125V  ?? 那这MOS on breakdown , off breakdown 分别多少 .  VIS 记得有 250V LDMOS + LIGBT ,  UMC 0.18UM 200v ldmos .
好像 100~200V  BCD 比较少看到 .
为何要找X-FAB ??   **不少代工厂有高压阿
发表于 2022-10-14 22:30:35 | 显示全部楼层
peterlin2010 发表于 2022-10-14 20:30
125V  ?? 那这MOS on breakdown , off breakdown 分别多少 .  VIS 记得有 250V LDMOS + LIGBT ,  UMC 0.18 ...
xfab用的是soi,技术不成熟,买了几个没用的ip自娱自乐。别和他们一般见识。
vishay技术不错,性价比也好,umc价格也就便宜一点,你在哪里高就呢?需要协助可以联系我。
至于帖子的主人为什么要x,我们就不讨论了吧,
发表于 2022-10-15 13:37:56 | 显示全部楼层
vishay技术不错,性价比也 ...
VIS =vanguard
GG = TSMC
 楼主| 发表于 2022-10-15 14:19:41 | 显示全部楼层
vishay技术不错,性价比也 ...
这个工艺是实验室老师给我们找的。
 楼主| 发表于 2022-10-15 14:20:40 | 显示全部楼层
D is the Drain  one
thanks
 楼主| 发表于 2022-10-15 14:21:43 | 显示全部楼层
这个工艺是我们实验室老师选的,我才刚开始学习
 楼主| 发表于 2022-10-15 14:25:29 | 显示全部楼层
vishay技术不错,性价比也 ...
实验室老师给的一个高压DC-DC的课题,刚开始学习,还请大佬们多多指点
发表于 2022-10-18 16:36:30 | 显示全部楼层
peterlin2010 发表于 2022-10-15 13:37
VIS =vanguard
GG = TSMC
interesting name, GG is Taijidian?
GMT+8, 2025-9-15 05:06 , Processed in 0.020993 second(s), 6 queries , Gzip On, Redis On.
