查看: 2297|回复: 1
[求助] 使用spyglass时报错: ./dotty/scripts/grep: /lib/ld-linux.so.2: bad ELF interpreter
发表于 2022-9-26 21:54:11 | 显示全部楼层 |阅读模式
错误内容:            sh: /home/eda_tool/spyglass/spyglass/SPYGLASS2018.09-SP1/SPYGLASS_HOME/../dotty/scripts/grep: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory。
按照网上解决方法尝试,结果如下:
# yum install glibc.i686
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /usr/lib64/libplc4.so)
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.6.6 (r266:84292, Aug  9 2016, 06:11:56)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-17)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://yum.baseurl.org/wiki/Faq
求各位大佬指点!!!
 楼主| 发表于 2022-10-4 23:15:59 | 显示全部楼层
原因:64位系统中安装了32位程序解决办法
解决方法1:yum install glibc.i686
          网上提及的最多的方法,本人尝试时报错: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found",没有细究原因,直接采用方法2(离线安装)。
解决方法2:
         首先下载离线包,链接如下:
         链接:https://pan.baidu.com/s/1mXxregN0B2qinDRvTwdyFg
         提取码:g7od
         然后进行安装:sh install.sh
         注:报错的话给每个*.rpm后加 -force --nodeps,再安装。
GMT+8, 2025-12-20 22:20 , Processed in 0.011269 second(s), 3 queries , Gzip On, Redis On.
