查看: 2602|回复: 2
[求助] TSMC018PDK中提到的每指栅宽范围最大是8um,但是设置的时候却可以超过8um,这是怎么回事
发表于 2022-9-2 09:49:49 | 显示全部楼层 |阅读模式
悬赏20资产已解决
最佳答案
查看完整内容
The doc. only guarantee the simulation will match measurement result well with single device L < 8um. If you set L>8um, it's fine. But your simluation result is meaningless.
发表于 2022-9-2 09:49:50 | 显示全部楼层
 楼主| 发表于 2022-9-5 15:05:59 | 显示全部楼层
diabol 发表于 2022-9-2 09:49
The doc. only guarantee the simulation will match measurement result well with single device L < 8um ...
thanks!!!
GMT+8, 2025-12-16 00:16 , Processed in 0.017250 second(s), 6 queries , Gzip On, Redis On.
