查看: 1982|回复: 1
[求助] 請問數位設計 constraint的問題
发表于 2022-6-29 08:01:26 | 显示全部楼层 |阅读模式
如下圖及波型
1. MEM 會在clk_div_2 下降緣 delay一段時間後吐出資料DOUT
2. clk_div_2下降緣 到資料穩定 之間的狀態是unknown
3. DFF 在clk上聲緣抓取資料DOUT
以下方波型圖RTL Sim來看
在T=t3時, clk_div_2有下降緣f1, MEM開始輸出DOUT=D2, T=t4時 DFF抓取D2
問題點 Post-sim(APR後) T=t4時 DOUT還沒穩定 導致DFF抓取到 unkown值
這在STA分析有辦法找出timing violation嗎?
請問sdc要如何設置?
        DFF
                                                 ________________                    ____
               _____      clk_div_2       |          MEM          |                   |     |
clk--|----->|div/2|------------------->| CLK           DOUT |-------------->|D   |
      |         -------                          |_______________|                  |     |
      |---------------------------------------------------------------------------->|CK |
RTL Sim
                                f1
                          ____        ____
clk_div_2     ____|      |____|      |_____
                   ________   _______   ____
DOUT         x___D1___xx__D2___xx____
                __     __    __     __    __
CK            |  |__|  |__|  |__|  |__|
                 t1    t2     t3     t4
Post-sim
                                    f1
                              ____        ____
                __     __    __     __    __
                 t1    t2     t3     t4
发表于 2022-6-29 11:08:00 | 显示全部楼层
In the waveform for RTL sim, clk_div_2 rising edge seems to align with CK rising edge.
In the waveform for Post-sim, clk_div_2 rising edge seems to align with CK falling edge.  In SDC, is the generated clock clk_div_2 defined properly?  Should be something like:
create_generated_clock -name clk_div_2 -source div2_reg/CK -edges {1 3 5} div2_reg/Q
MEM is generally slow.  I would change the design, implement a multicycle path to make it easier to meet timing.
GMT+8, 2025-12-21 05:55 , Processed in 0.012469 second(s), 4 queries , Gzip On, Redis On.
