查看: 2974|回复: 2
[求助] 求助工艺角仿真错误怎么解决
发表于 2022-6-15 14:56:11 | 显示全部楼层 |阅读模式
楼主先仿了一个反相器的corner,先跑了nominal,这个时候是正常的,然后如果跑其他的工艺角时候在run summary的log文件里会报错,请问这个问题怎么解决啊:\o    ---> Init... Successfully register new user trigger
\o    ---> Init... New session = stdobj@0x1ee110e0          session-class = spectre_session
\o    ---> ADE Session spectre_session
\o    ---> Initializing spectre model setup
\o    ---> Initializing ams model setup
\o    ---> Initializing hspiceD model setup
\e *Error* Error during configuration of remote session.
\e ("hiGetBannerMenus" 0 t nil ("*Error* hiGetBannerMenus: argument #1 should be a window type (type template = \"w\")" nil))
\e
\e
\o
\o *Error*   Error ID  = 5000
\o *Error*   Error Msg = Error while configuring the job.
\o
\o
\o
\o
\o Job 10 timed out after no activity in 300 seconds.
\o
\o *Info*    Received signal SIGTERM.
\o
 楼主| 发表于 2022-8-18 10:18:24 | 显示全部楼层
求助求助
发表于 2024-4-29 10:38:38 | 显示全部楼层
楼主解决了吗
GMT+8, 2025-9-14 08:16 , Processed in 0.013837 second(s), 4 queries , Gzip On, Redis On.
