查看: 14059|回复: 89
[资料] USB3.1SSP+/DP Alt PHY 特点和描述
发表于 2022-6-9 08:13:02 | 显示全部楼层 |阅读模式
Type-C - USB3.1SSP+/DPAlt PHY provides fullduplex transceiver pair for USB and a maximum 4 Transmit lanes for DP or HDMI operation and consists of the following:
■ A hard macro (physical medium attachment (PMA)/SerDes)
■ A soft RTL module (raw physical coding sublayer (PCS):
The PHY provides the following features:
■ Highly customizable physical medium attachment (PMA) configuration (controlled by PCS):
❑ Configurable serial data:
❑ USB3.1SSP+ data rates:
5Gbps,
10Gbps
❑ DP Alt data rates:
1.620Gbps
2.700Gbps
5.400Gbps
8.100Gbps
❑ Quad channel macros configurations lanes for multiport Type-C - USB3.1SSP+/DPAlt PHY.
❑ Extensive PMA debug capability through read/write and read-only registers in PCS.
❑ Register-based control of all PCS-to-PMA signals.
❑Adaptive and configurable RX continuous time linear equalizer (CTLE) and decision feedback
equalizer (DFE).
❑ Programmable TX equalization.
■ IEEE 1149.1 and 1149.6 (AC JTAG) boundary scan.
■ Built-in Self-Test (BIST) features for production ; at-speed testing on any digital tester.
■ Advanced, built-in diagnostics including on-chip sampling scope.
■ Visibility and controllability of hard macro functions through programmable registers in the design:
❑ Overrides on all asic  side functional control inputs for easy debug .
❑ Access register space through a parallel interface.
❑ Access register space through a JTAG port.
■ Configurable PCS with extensive debug options:
❑ Independent TX and RX control per lane.
❑ Configurable TX and RX power modes .
❑ Pseudo-random bit sequence (PRBS) generation and checker (PRBS31, PRBS23, PRBS16, PRBS15,
PRBS11, PRBS9, PRBS7).
❑ Programmable 10-bit pattern generation with error injection capability.
■ Built-in, on-chip SSC generation and full configuration from -5000ppm to +5000ppm with a
maximum range of 5000ppm.
■ A reference clock repeater for other modules.
■ Supports flip-chip packaging
游客 ,如果您要查看本帖隐藏内容请回复
发表于 2022-6-9 08:52:02 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-9 09:47:14 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-9 11:28:33 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-9 20:46:25 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-12 01:30:45 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-12 11:14:34 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-12 16:35:09 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-20 15:39:17 | 显示全部楼层
此帖仅作者可见
发表于 2022-6-21 15:59:26 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-10-19 10:59 , Processed in 0.020339 second(s), 5 queries , Gzip On, Redis On.
