楼主: benemale
『三味书屋』元旦送礼之七:著名的Kluwer丛书系列 Volume 494~672
 楼主| 发表于 2008-1-5 01:02:34 | 显示全部楼层
经典的书,论坛已有好象是扫描版,这里是原版文字版,需要打印或收藏的再下吧。
CMOS Data Converters for Communications
Series: The Springer International Series in Engineering and Computer Science , Vol. 543
Gustavsson, Mikael, Wikner, J. Jacob, Nianxiong Tan
2000, 404 p., Hardcover
ISBN: 978-0-7923-7780-1
Ships in 3 - 5 business days
$249.00
About this book
Table of contents
About this book
CMOS Data Converters for Communications distinguishes itself from other data converter books by emphasizing system-related aspects of the design and frequency-domain measures. It explains in detail how to derive data converter requirements for a given communication system (baseband, passband, and multi-carrier systems). The authors also review CMOS data converter architectures and discuss their suitability for communications. The rest of the book is dedicated to high-performance CMOS data converter architecture and circuit design. Pipelined ADCs, parallel ADCs with an improved passive sampling technique, and oversampling ADCs are the focus for ADC architectures, while current-steering DAC modeling and implementation are the focus for DAC architectures. The principles of the switched-current and the switched-capacitor techniques are reviewed and their applications to crucial functional blocks such as multiplying DACs and integrators are detailed. The book outlines the design of the basic building blocks such as operational amplifiers, comparators, and reference generators with emphasis on the practical aspects. To operate analog circuits at a reduced supply voltage, special circuit techniques are needed. Low-voltage techniques are also discussed in this book.
CMOS Data Converters for Communications can be used as a reference book by analog circuit designers to understand the data converter requirements for communication applications. It can also be used by telecommunication system designers to understand the difficulties of certain performance requirements on data converters. It is also an excellent resource to prepare analog students for the new challenges ahead.
[ 本帖最后由 benemale 于 2008-1-5 02:09 编辑 ]
CMOS Data Converter for Communications.part01.rar
4.43 MB, 下载次数: 312 , 下载积分: 资产 -3 信元, 下载支出 3 信元
CMOS Data Converter for Communications.part02.rar
4.43 MB, 下载次数: 322 , 下载积分: 资产 -3 信元, 下载支出 3 信元
CMOS Data Converter for Communications.part03.rar
4.43 MB, 下载次数: 383 , 下载积分: 资产 -3 信元, 下载支出 3 信元
CMOS Data Converter for Communications.part04.rar
4.43 MB, 下载次数: 363 , 下载积分: 资产 -3 信元, 下载支出 3 信元
CMOS Data Converter for Communications.part05.rar
4.43 MB, 下载次数: 308 , 下载积分: 资产 -3 信元, 下载支出 3 信元
CMOS Data Converter for Communications.part06.rar
4.01 MB, 下载次数: 314 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-1-5 01:03:51 | 显示全部楼层
Design and Analysis of Integrator-Based Log-Domain Filter Circuits_resize.jpg
Series: The Springer International Series in Engineering and Computer Science , Vol. 534
Roberts, Gordon W., Leung, Vincent W.
2000, 280 p., Hardcover
ISBN: 978-0-7923-8699-5
This item usually ships in 2-3 business days
$209.00
About this book
Table of contents
About this book
Design and Analysis of Integrator-Based Log-Domain Filter Circuits deals with the design and analysis of log-domain filter circuits. It describes several synthesis methods that aid the designer in developing bipolar or BiCMOS filter circuits with cut-off frequencies ranging from the low kilohertz range to several hundreds of megahertz. Filter response deviations due to transistor-level nonidealities are systematically analyzed, leading to effective electronic compensation schemes. Numerous examples are provided in the text with measured experimental data from IC prototypes. Design and Analysis of Integrator-Based Log-Domain Filter Circuits is intended for engineers in research or development, as well as advanced-level engineering students. Extensive discussion on filter text metrics should also interest engineers who are responsible for testing high-performance, high-speed analog or mixed-signal products.
[ 本帖最后由 benemale 于 2008-1-5 09:39 编辑 ]
Design and Analysis of Integrator-Based Log-Domain Filter Circuits.part1.rar
4.67 MB, 下载次数: 435 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Design and Analysis of Integrator-Based Log-Domain Filter Circuits.part2.rar
4.67 MB, 下载次数: 365 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Design and Analysis of Integrator-Based Log-Domain Filter Circuits.part3.rar
4.62 MB, 下载次数: 363 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-1-5 01:05:14 | 显示全部楼层
Continuous-Time Delta-Sigma Modulators for High-Speed A/D Conversion  Theory, Practice and Fundamental Performance Limits
Series: The Springer International Series in Engineering and Computer Science , Vol. 521
Cherry, James A., Snelgrove, W. Martin
1999, 280 p., Hardcover
ISBN: 978-0-7923-8625-4
$235.00
About this book
Table of contents
About this book
Among analog-to-digital converters, the delta-sigma modulator has cornered the market on high to very high resolution converters at moderate speeds, with typical applications such as digital audio and instrumentation. Interest has recently increased in delta-sigma circuits built with a continuous-time loop filter rather than the more common switched-capacitor approach. Continuous-time delta-sigma modulators offer less noisy virtual ground nodes at the input, inherent protection against signal aliasing, and the potential to use a physical rather than an electrical integrator in the first stage for novel applications like accelerometers and magnetic flux sensors. More significantly, they relax settling time restrictions so that modulator clock rates can be raised. This opens the possibility of wideband (1 MHz or more) converters, possibly for use in radio applications at an intermediate frequency so that one or more stages of mixing might be done in the digital domain.
Continuous-Time Delta-Sigma Modulators for High-Speed A/D Conversion: Theory, Practice and Fundamental Performance Limits covers all aspects of continuous-time delta-sigma modulator design, with particular emphasis on design for high clock speeds. The authors explain the ideal design of such modulators in terms of the well-understood discrete-time modulator design problem and provide design examples in Matlab. They also cover commonly-encountered non-idealities in continuous-time modulators and how they degrade performance, plus a wealth of material on the main problems (feedback path delays, clock jitter, and quantizer metastability) in very high-speed designs and how to avoid them. They also give a concrete design procedure for a real high-speed circuit which illustrates the tradeoffs in the selection of key parameters. Detailed circuit diagrams, simulation results and test results for an integrated continuous-time 4 GHz band-pass modulator for A/D conversion of 1 GHz analog signals are also presented.
Continuous-Time Delta-Sigma Modulators for High-Speed A/D Conversion: Theory, Practice and Fundamental Performance Limits concludes with some promising modulator architectures and a list of the challenges that remain in this exciting field.
[ 本帖最后由 benemale 于 2008-1-7 12:30 编辑 ]
Continuous-Time Delta-Sigma Modulators for High-Speed AD Conversion.part1.rar
3.94 MB, 下载次数: 618 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Continuous-Time Delta-Sigma Modulators for High-Speed AD Conversion.part2.rar
3.47 MB, 下载次数: 631 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-1-5 01:16:18 | 显示全部楼层
网上偶得一本,扫描版的,已经添加封面与书签目录,作者是TI、ST、MOTOROLA、IBM的工程师,IC方面的FEMA书籍。
Failure Analysis of Integrated CircuitsTools and Techniques
Series: The Springer International Series in Engineering and Computer Science , Vol. 494
Wagner, Lawrence C. (Ed.)
1999, 216 p., Hardcover
ISBN: 978-0-412-14561-2
$209.00
About this book
Table of contents
About this book
Failure Analysis of Integrated Circuits: Tools and Techniques provides a basic understanding of how the most commonly used tools and techniques in silicon-based semiconductors are applied to understanding the root cause of electrical failures in integrated circuits. These include applications specific to performing failure analysis such as decapsulation, deprocessing, and fail site isolation, as well as physical and chemical analysis tools and techniques. The coverage is qualitative, and it provides a general understanding for making intelligent tool choices. Also included is coverage of the shortcomings, limitations, and strengths of each technique.
Failure Analysis of Integrated Circuits: Tools and Techniques is a `must have' reference work for semiconductor professionals and researchers.
[ 本帖最后由 benemale 于 2008-1-5 09:51 编辑 ]
Failure Analysis of Integrated Circuits Tools and Techniques.part1.rar
3.47 MB, 下载次数: 579 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Failure Analysis of Integrated Circuits Tools and Techniques.part2.rar
3.47 MB, 下载次数: 623 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Failure Analysis of Integrated Circuits Tools and Techniques.part3.rar
3.2 MB, 下载次数: 577 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-5 03:07:31 | 显示全部楼层
都是好书
中间几本没附件哦
发表于 2008-1-5 03:09:34 | 显示全部楼层
再次定以下
发表于 2008-1-5 08:17:45 | 显示全部楼层
发表于 2008-1-5 08:31:56 | 显示全部楼层
中间有几本好书没有附件,怎么回事呢?
发表于 2008-1-5 09:16:27 | 显示全部楼层
Direct Conversion Receivers in Wide-Band Systems  不全 啊
 楼主| 发表于 2008-1-5 09:19:04 | 显示全部楼层
GMT+8, 2025-12-25 21:27 , Processed in 0.047712 second(s), 4 queries , Gzip On, Redis On.
