查看: 2870|回复: 1
[求助] 求助icc导入sdc后出现这些warning需要管么?可以详细解释一下吗?怎样解决呢?
发表于 2022-5-14 15:24:09 | 显示全部楼层 |阅读模式
悬赏120资产未解决
Reading SDC version 2.0...
Warning: SDC version in file (1.7) does not match the version you requested
        from read_sdc (2.0).  Some constraints and options may not function. (SDC-2)
Using operating conditions 'typical' found in library 'csmc018_typ'.
Warning: Constraint 'set_wire_load_mode' is not supported by icc_shell. (SDC-3)
Warning: Creating virtual clock named 'vclk' with no sources. (UID-348)
Summary of unsupported constraints:
Information: Ignored 1 unsupported 'set_wire_load_mode' constraint. (SDC-4)
Info: hierarchy_separator was changed to /
1
发表于 2022-5-16 18:39:08 | 显示全部楼层
这不就是sdc文件的版本太低了吗,导致很多命令已经不适用了,综合的时候把版本升级到2.0
GMT+8, 2025-12-17 18:54 , Processed in 0.130319 second(s), 4 queries , Gzip On, Redis On.
