查看: 2486|回复: 2
[求助] 模9计数器实现简单的9分频计数器,占空比为5/9
发表于 2022-4-5 00:46:43 | 显示全部楼层 |阅读模式
但是功能仿真一直提示counter_9 值不确定,有没有大佬知道这是什么原因造成的呢?
module top_temp(
     clk,
     rst,
     rd_clk,
     wr_clk
input clk;
input rst;
output reg rd_clk;
output reg wr_clk;
reg [4:0] counter_9;
always @ ( posedge clk )
begin
if( rst || counter_10==4'b1001)
    counter_10 <= 4'b0000;
else
    counter_10 <= counter_10+1;
end
begin
if( rst || counter_9==4'b1000)
    counter_9 <= 4'b0000;
else
    counter_9 <= counter_9+1;
end
//div9 rd_clk
begin
if( rst ) begin
rd_clk <= 1'b0;
end
else begin
case(counter_9)
    4'd0 : rd_clk <= 1'b0;
    4'd1 : rd_clk <= 1'b0;
    4'd2 : rd_clk <= 1'b0;
    4'd3 : rd_clk <= 1'b0;
    4'd4 : rd_clk <= 1'b1;
    4'd5 : rd_clk <= 1'b1;
    4'd6 : rd_clk <= 1'b1;
    4'd7 : rd_clk <= 1'b1;
    4'd8 : rd_clk <= 1'b1;
default : rd_clk <= 1'b0;
endcase
end
end
发表于 2022-4-5 02:15:43 | 显示全部楼层
  1. module top_temp(
  2.                 clk,
  3.                 rst,
  4.                 rd_clk,
  5.                 wr_clk
  6.                 );
  7.    input clk;
  8.    input rst;
  9.    output reg rd_clk;
  10.    output reg wr_clk;
  11.    reg [3:0]  counter_9;
  12.    reg [3:0]  counter_10;
  13.
  14.    always [url=home.php?mod=space&uid=1769321]@[/url] ( posedge clk ) begin
  15.       if( rst || counter_10==4'b1001)
  16.         counter_10 <= 4'b0000;
  17.       else
  18.         counter_10 <= counter_10+1;
  19.    end
  20.    always @ ( posedge clk ) begin
  21.       if( rst || counter_9==4'b1000)
  22.         counter_9 <= 4'b0000;
  23.       else
  24.         counter_9 <= counter_9 +1;
  25.    end
  26.    //div9 rd_clk
  27.    always @ ( posedge clk ) begin
  28.       if ( rst ) begin
  29.          rd_clk <= 1'b0;
  30.       end
  31.       else begin
  32.          case(counter_9)
  33.            4'd0 : rd_clk <= 1'b0;
  34.            4'd1 : rd_clk <= 1'b0;
  35.            4'd2 : rd_clk <= 1'b0;
  36.            4'd3 : rd_clk <= 1'b0;
  37.            4'd4 : rd_clk <= 1'b1;
  38.            4'd5 : rd_clk <= 1'b1;
  39.            4'd6 : rd_clk <= 1'b1;
  40.            4'd7 : rd_clk <= 1'b1;
  41.            4'd8 : rd_clk <= 1'b1;
  42.            default : rd_clk <= 1'b0;
  43.          endcase
  44.       end // else: !if( rst )
  45.    end // always @ ( posedge clk )
  46. endmodule // top_temp
  47. module test();
  48.    reg clk,rst;
  49.    wire rd_clk;
  50.    wire wr_clk;
  51.    top_temp top_temp(// Outputs
  52.                      .rd_clk            (rd_clk),
  53.                      .wr_clk            (wr_clk),
  54.                      // Inputs
  55.                      .clk               (clk),
  56.                      .rst               (rst));
  57.    initial begin
  58.       clk =0;
  59.       rst=1;
  60.       #33 rst=0;
  61.       #500 $finish;
  62.    end
  63.    always #5 clk = ~clk;
  64.
  65. endmodule // test
  66.
    复制代码
Works OK!
 楼主| 发表于 2022-4-10 12:27:55 | 显示全部楼层
感谢感谢!
GMT+8, 2025-12-21 17:24 , Processed in 0.012579 second(s), 3 queries , Gzip On, Redis On.
