查看: 3867|回复: 2
[求助] tran仿真在ADE L里可以跑,在ADE XL里就出错
发表于 2022-3-23 02:58:21 | 显示全部楼层 |阅读模式
打算在ADE XL里跑个蒙特卡洛,需要跑tran仿真但是在ADE XL里跑tran仿真就会报错如下:
Error found by spectre during circuit read-in.
    ERROR (SFE-874): "input.scs" 23191: Cannot run the simulation because syntax error `Unexpected close square bracket "]"' was encountered at line 23191, column 38. Correct the syntax error and rerun the simulation.
    ERROR (SFE-841): "input.scs" 23192: Cannot run the simulation because an unexpected character '[' was found at line 23192 in the netlist. Correct the syntax error and rerun the simulation.
定位到23191和23192行,可以发现:
writefinal="spectre.fc" savetime=[] annotate=status infotime_pair=no \
    infotimes=[] actime_pair=no actimes=[] acnames=[] maxiters=5 \
也看不出是什么意思啊
但是我在ADE L里跑tran仿真是没有问题的,有人知道这个问题怎么解决吗?
发表于 2023-4-14 15:40:59 | 显示全部楼层
楼主解决了么,我也遇到这个问题
发表于 2024-11-8 14:46:53 | 显示全部楼层
遇到同样的问题,不识别"<"和"["
GMT+8, 2025-12-29 20:55 , Processed in 0.012804 second(s), 3 queries , Gzip On, Redis On.
