发表于 2022-3-23 02:28:04
显示全部楼层
- setenv ASSURA_HOME /assura_install_directory
复制代码
this code is for csh shell. If the server uses bash shell, please modify it as below
- export ASSURA_HOME=/assura_install_directory
复制代码
After complete, please check if assura is ready
# if the return message shows the correct assura installation directory, it is ready to use.
