查看: 3266|回复: 7
[求助] 文件导入QRC文件显示error,显示can‘t read
发表于 2022-3-22 18:13:05 | 显示全部楼层 |阅读模式
Extraction setup Started
Initializing multi-corner RC extraction with 1 active RC Corners ...
Process node set using 'setDesignMode' is less than or equal to 32nm, for which captable file(s) would be ignored as preRoute extraction would instead use technology file. For postRoute extraction, default value for effort level would be 'medium' and effort level 'low' would not be allowed.
Generating auto layer map file.
**ERROR: (IMPEXT-1226):        Only 8 metal layers found in technology file '/work/home/yfma/lib/TSMC_22NM_ULL/RC/QRC/qrcTechFile'. 11 expected as per LEF data of Innovus. Cannot proceed. The data in the Quantus QRC technology file should be consistent with the layer information in the LEF data. Modify the ICT file based on layer information in the LEF file and regenerate the Quantus QRC technology file.
**ERROR: (IMPEXT-6189):        Initialization for preRoute extraction mode using the technology file is being terminated since the technology file '/work/home/yfma/lib/TSMC_22NM_ULL/RC/QRC/qrcTechFile' could not be read. This is because it is either an invalid file or an error occurred in importing it. Check the file and read it in again using create_rc_corner or update_rc_corner -qx_tech_file.
Type 'man IMPEXT-6189' for more detail.
发表于 2022-3-23 14:25:30 | 显示全部楼层
qrc和lef的金属层数不对应
 楼主| 发表于 2022-3-24 09:40:42 | 显示全部楼层
lzqxiang 发表于 2022-3-23 14:25
qrc和lef的金属层数不对应
嗯嗯,谢谢了,是这个原因,已经搞定了,多问一句你知道工艺lef里面PRTF_Innovus_22nm_7M_4X1Z1UUTRDL_7T.11_1a.tlef  ,像这种4X1Z1UUTRDL,里面4x1z1u代表什么意思么,我也没找到对应的文档说明
发表于 2022-3-24 09:46:40 | 显示全部楼层
Clearpeng 发表于 2022-3-24 09:40
嗯嗯,谢谢了,是这个原因,已经搞定了,多问一句你知道工艺lef里面PRTF_Innovus_22nm_7M_4X1Z1UUTRDL_7T ...
4X肯定是4层普通金属,其他的就不知道了,要去问问模拟
 楼主| 发表于 2022-3-24 10:13:26 | 显示全部楼层
好的,感谢
发表于 2024-1-16 09:47:25 | 显示全部楼层
请问怎么解决的,我在做项目也遇见这样的问题了
 楼主| 发表于 2024-3-1 11:55:57 | 显示全部楼层
前面说了啊,qrc和tech lef的金属层数对不上,检查一下tech lef
发表于 2024-6-4 16:52:09 | 显示全部楼层
我看 tech lef 好像是没问题的,QRC 是二进制也没法看里面的金属层,这个怎么办?
找Foundry 重新提供一份QRC出来么?
GMT+8, 2025-12-19 01:26 , Processed in 0.018006 second(s), 3 queries , Gzip On, Redis On.
