查看: 2968|回复: 4
[求助] Cascold电流镜
发表于 2022-3-20 14:13:51 | 显示全部楼层 |阅读模式
悬赏50资产已解决
Cascold电流镜 输出电压下降,哪个管子先进入线性区,为什么?谢谢
最佳答案
查看完整内容
M2 will enter the triode region first. As M2 drain voltage (Vd2=Vout) drops, and its gate voltage (Vg2=Vin) is constant, two things should happen: 1) Drain voltage of M1 is pinned as VGS2 is constant (Vin-Vth) --> So M1 is still maintained in SAT region. 2) VGD2 should be smaller than Vth, so if the difference increased beyond Vth (as Vout drops, Vin-Vout increases) then M2 will enter Triode reg ...
发表于 2022-3-20 14:13:52 | 显示全部楼层
2) VGD2 should be smaller than Vth, so if the difference increased beyond Vth (as Vout drops, Vin-Vout increases) then M2 will enter Triode region.
Hope this helps
发表于 2022-3-20 15:23:53 | 显示全部楼层
拉扎维P129页
假设下面的管子M1先进入线性区,Vds减小而Vgs1是不变的,那么Id1会下降。Id1和Id2下降但是Vd1下降说明VGs2是上升的。显然不成立,所以M2先进入线性区。
 楼主| 发表于 2022-3-21 20:10:39 | 显示全部楼层
vaeping123 发表于 2022-3-20 15:23
拉扎维P129页
假设下面的管子M1先进入线性区,Vds减小而Vgs1是不变的,那么Id1会下降。Id1和Id2下降但是Vd1 ...
谢谢!
 楼主| 发表于 2022-3-21 20:11:52 | 显示全部楼层
As M2 drain voltage (Vd2=Vout) drops, and its gate voltage ( ...
Thanks for your help!
GMT+8, 2025-12-17 02:24 , Processed in 0.017261 second(s), 6 queries , Gzip On, Redis On.
