查看: 2078|回复: 1
[求助] innovus打stripe时怎么设置孔的形状
发表于 2022-3-11 16:17:57 来自手机 | 显示全部楼层 |阅读模式
如标题 innovus打stripe时怎么设置孔的形状啊?
发表于 2022-3-16 10:39:26 | 显示全部楼层
  if {$SIGNOFF_DRC_ENGINE == "HERCULES"} {     signoff_drc -read_cel_view                         } elseif { $SIGNOFF_DRC_ENGINE == "ICV"} {     signoff_drc -read_cel_view -ignore_child_cell_errors -user_defined_options {-holding_cell}        # Generate autofix config_file     if {![file exists [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file]} {     exec $env(ICV_HOME_DIR)/contrib/generate_layer_rule_map.pl \           -dplog ./signoff_drc_run/run_details/[file tail [file rootname ${SIGNOFF_DRC_RUNSET}]].dp.log \           -tech_file ${TECH_FILE} \           -o [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file     }          signoff_autofix_drc -config_file [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file \                         -init_drc_error_db signoff_drc_run      # Save cell as signoff_drc works on data on disk     save_mw_cel     signoff_drc -read_cel_view                         }  }
GMT+8, 2025-9-14 13:47 , Processed in 0.011295 second(s), 3 queries , Gzip On, Redis On.
