查看: 12768|回复: 71
Bias generator design
发表于 2007-12-31 19:14:23 | 显示全部楼层 |阅读模式
BIAS CURRENT GENERATORS WITH WIDE DYNAMIC RANGE
Tobi Delbrück1, André van Schaik2
ABSTRACT
Mixed-signal or analog chips often require a wide range of biasing currents that are independent of process and supply voltage and that are proportional to absolute temperature. This paper describes CMOS circuits that we use to generate a set of fixed bias currents typically spanning six decades at room temperature down to a few times the transistor off-current. A bootstrapped current reference with a new startup and power-control mechanism generates a master current, which is successively divided by a current splitter to generate the desired reference currents. These references are nondestructively copied to form the chip’s biases. Measurements of behavior, including temperature effects from 1.6μ and 0.35μ implementations, are presented and nonidealities are investigated. Temperature dependence of the transistor off-current is investigated because it determines the lower limit for generated currents. Readers are directed to a design kit that allows easy generation of the complete layout for a bias generator with a set of desired currents for scalable MOSIS CMOS processes.
Key Words: bias current generator, current reference, current splitter, current divider, PTAT
共42页,
BIAS CURRENT GENERATORS WITH WIDE DYNAMIC RANGE.pdf
1.14 MB, 下载次数: 409 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-12-31 22:49:01 | 显示全部楼层
good stuff, thanks for share~
 楼主| 发表于 2008-1-1 01:49:43 | 显示全部楼层
好东西自己顶一下!!
发表于 2008-1-1 08:46:09 | 显示全部楼层
正好要做一个低压偏置,看看有帮助不?
发表于 2008-1-1 14:55:09 | 显示全部楼层
真的很不错,谢谢!
发表于 2008-1-1 15:04:39 | 显示全部楼层
Thanks for your share!!
发表于 2008-1-1 21:27:40 | 显示全部楼层
ddddddddddd
发表于 2008-1-1 22:06:00 | 显示全部楼层
赞一个,确实不错。
发表于 2008-1-1 22:58:49 | 显示全部楼层
头像被屏蔽
发表于 2008-1-1 23:28:18 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-26 15:03 , Processed in 0.023814 second(s), 8 queries , Gzip On, Redis On.
