查看: 3302|回复: 5
[求助] virtuoso 把gds转def
发表于 2022-3-4 20:07:22 | 显示全部楼层 |阅读模式
   需要导出一些金属连线给到后端,在virtuoso CIW 用export ->def导出def, 转出来的def里面via被过滤了,请问有人知道如何转出正确的def吗?
发表于 2022-3-5 18:01:09 | 显示全部楼层
被过滤的VIA有connectivity的属性吗
发表于 2022-3-16 10:43:09 | 显示全部楼层
  if {$SIGNOFF_DRC_ENGINE == "HERCULES"} {
    signoff_drc -read_cel_view
  } elseif { $SIGNOFF_DRC_ENGINE == "ICV"} {
    signoff_drc -read_cel_view -ignore_child_cell_errors -user_defined_options {-holding_cell}
    # Generate autofix config_file
    if {![file exists [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file]} {
    exec $env(ICV_HOME_DIR)/contrib/generate_layer_rule_map.pl \
          -dplog ./signoff_drc_run/run_details/[file tail [file rootname ${SIGNOFF_DRC_RUNSET}]].dp.log \
          -tech_file ${TECH_FILE} \
          -o [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file
    signoff_autofix_drc -config_file [file tail [file rootname ${SIGNOFF_DRC_RUNSET}]]_config_file \
                        -init_drc_error_db signoff_drc_run
    # Save cell as signoff_drc works on data on disk
    save_mw_cel
发表于 2022-3-16 15:12:29 | 显示全部楼层
v2lvs -s ref_lib_file -v verilog_file -o spice_file  ref_lib_file:参考的标准单元库 verilog_file:需要进行转换的verilog网表(APR后生成的网表) spice_file:期望生成的spice网表
 楼主| 发表于 2022-3-24 20:07:14 | 显示全部楼层
  导出前给金属线和via都加上net命名,就能导出了
 楼主| 发表于 2022-3-24 20:08:55 | 显示全部楼层
  } elseif { $SIGN ...
多谢大佬,我试试
GMT+8, 2025-10-28 06:52 , Processed in 0.022023 second(s), 5 queries , Gzip On, Redis On.
