查看: 11563|回复: 52
PLL With Adaptive Phase Noise Cancellation
发表于 2007-12-31 12:06:04 | 显示全部楼层 |阅读模式
Abstract—A fast-settling adaptive calibration technique is presented that makes phase noise cancelling  fractional- PLLs practical for the low reference frequencies commonly used in wireless communication systems. The technique is demonstrated as an enabling component of a 2.4 GHz ISM band CMOS PLL IC with a 730 kHz bandwidth, a 12MHz reference, and an on-chip loop filter. In addition to the adaptive calibration technique, the IC incorporates
a dynamic charge pump biasing technique to reduce power dissipation. The worst-case phase noise of the IC is 101 dBc/Hz and 124 dBc/Hz at 100 kHz and 3 MHz offsets, respectively, and the adaptive phase noise cancellation technique has a worst-case settling time of 35 s. The IC is implemented in 0.18 m CMOS technology. It measures 2.2 2.2 mm2, and its core circuitry consumes 20.9 mA from a 1.8 V supply
DECEMBER 2007 newly published
04381465.pdf
2.82 MB, 下载次数: 398 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-2 10:36:25 | 显示全部楼层
thank you
发表于 2008-1-2 11:28:00 | 显示全部楼层
只是IEEE的文章还以为是book  ,偻猪就是骗人,
发表于 2008-1-3 19:17:27 | 显示全部楼层
88888
gooooooooood
发表于 2008-1-3 20:09:09 | 显示全部楼层
个人认为这篇文章挺好的
 楼主| 发表于 2008-1-4 11:46:42 | 显示全部楼层
发表于 2008-1-4 12:01:14 | 显示全部楼层
bu zen me yang ma
 楼主| 发表于 2008-1-4 12:59:43 | 显示全部楼层
不要期望能用一篇文章解决所有问题,能给人启迪的文章就是好的
发表于 2008-2-26 19:48:42 | 显示全部楼层
dddddddddddddddd
发表于 2008-4-16 22:03:51 | 显示全部楼层
dingding
GMT+8, 2025-12-22 08:50 , Processed in 0.033935 second(s), 8 queries , Gzip On, Redis On.
