查看: 2874|回复: 12
[资料] Vasilakopoulos_Konstantinos_202111_PhD_thesis Mixed-signal Processing Techniques for RF Transmitters
发表于 2022-1-30 22:34:43 | 显示全部楼层 |阅读模式
Vasilakopoulos_Konstantinos_202111_PhD_thesis Mixed-signal Processing Techniques.pdf (17.5 MB , 下载次数: 114 )
The design of high performance integrated radio frequency (RF) transmitters (TX) able to meet
the constant demand for faster, “greener”, and more cost-effective wireless communication links, is
driving innovation on all fronts: device, circuit, and system level. Recent advances in advanced
CMOS process nodes are pushing for more “digital-intensive” architectures, yet certain aspects of
analog integrated circuits (ICs) cannot be easily replaced by digital functions. This thesis aims to
take a fresh approach at the circuit and system level by proposing two designs that lie at the border
between digital and analog domains.
The first part of the thesis focuses on the design of a wireless TX front end based on the
concept of time-variant passive signal processing. The digital-to-analog converter (DAC) is merged
with a higher order passive switched-capacitor filter (PSCF) and so the functionalities of digitalto-analog conversion, baseband filtering, and signal upconversion are implemented by a passive
switched capacitor (PSC) network. The resulting passive switched-capacitor DAC (PSC-DAC) offers
a versatile architecture that fully benefits from CMOS scaling. The front end was integrated in
a 65nm CMOS technology and can support various channel bandwidths simply by adjusting the
switching frequency for the PSC network. Thanks to its third-order reconfigurable filter, it maintains
a thermal noise floor better than −156 dBc/Hz at a power dissipation of 45 mW. The measured
prototype achieves an alternate adjacent channel leakage ratio (ACLR2) of −57 dB and an error
vector magnitude (EVM) of −31 dB for a 20-MHz 64-QAM OFDM and a 20-MHz 16-QAM signal,
respectively.
In the second part, quantized analog (QA) signal processing is applied for the first time in RF
power amplification culminating in the concept of the quantized analog power amplifier (QA-PA).
By allowing the signal to virtually exceed the supply, the QA-PA leads to an improvement in the
output dynamic range that is not possible by conventional analog techniques. Simulations of a 65nm
CMOS design show good agreement with the presented theory and predict up to 18dB improvement
in both EVM and adjacent channel leakage ratio (ACLR) compared to an analog class-A power
amplifier (PA) for a 256-QAM, 100MHz 5G signal.
发表于 2022-1-31 08:44:33 | 显示全部楼层
Thanks for sharing
发表于 2022-1-31 13:27:53 | 显示全部楼层
kanakn
发表于 2022-1-31 14:11:39 | 显示全部楼层
:victory:
发表于 2022-2-1 15:47:59 | 显示全部楼层
多谢分享。
发表于 2022-2-4 12:52:51 | 显示全部楼层
Thanks!!!
发表于 2022-2-4 13:24:30 | 显示全部楼层
谢谢分享
发表于 2022-2-6 15:49:37 | 显示全部楼层
发表于 2022-3-17 16:30:25 | 显示全部楼层
Thanks
发表于 2022-3-17 16:37:02 | 显示全部楼层
3q for share~
GMT+8, 2025-12-4 19:47 , Processed in 0.020122 second(s), 5 queries , Gzip On, Redis On.
