查看: 2405|回复: 0
[求助] yosys综合脚本优化问题
发表于 2021-12-27 17:04:32 | 显示全部楼层 |阅读模式
悬赏100资产未解决
请问有大佬会用yosys综合的脚本吗?下方贴出的是本人的yosys综合脚本,但是综合出来的结果不是很好,所以想请教一下有没有大佬会改的,万分感谢!脚本:
# Yosys synthesis script for ${TOP_MODULE}
# Parse input files
# Read verilog files
${READ_VERILOG_FILE}
# Read technology library
read_verilog -lib -specify ${YOSYS_CELL_SIM_VERILOG}
# Prepare for synthesis
# Identify top module from hierarchy
hierarchy -check -top ${TOP_MODULE}
# - Convert process blocks to AST
proc
# Flatten all the gates/primitives
flatten
# Identify tri-state buffers from 'z' signal in AST
# with follow-up optimizations to clean up AST
tribuf -logic
opt_expr
opt_clean
# demote inout ports to input or output port
deminout
opt
opt_expr
opt_clean
check
opt
wreduce -keepdc
peepopt
pmuxtree
opt_clean
# Map multipliers
# Inspired from synth_xilinx.cc
# Avoid merging any registers into DSP, reserve memory port registers first
memory_dff
wreduce t: $mul
techmap -map +/mul2dsp.v -map ${YOSYS_DSP_MAP_VERILOG} ${YOSYS_DSP_MAP_PARAMETERS}
select a:mul2dsp
setattr -unset mul2dsp
opt_expr -fine
wreduce
select -clear
chtype -set $mul t: $__soft_mul# Extract arithmetic functions
# Run coarse synthesis
# Run a tech map with default library
techmap
alumacc
share
opt
fsm
# Run a quick follow-up optimization to sweep out unused nets/signals
opt -fast
# Optimize any memory cells by merging share-able ports and collecting all the ports belonging to memorcy cells
memory -nomap
opt_clean
# Map logics to BRAMs
memory_bram -rules ${YOSYS_BRAM_MAP_RULES}
techmap -map ${YOSYS_BRAM_MAP_VERILOG}
opt -fast -mux_undef -undriven -fine
memory_map
opt -undriven -fine
# Map flip-flops
techmap -map ${YOSYS_DFF_MAP_VERILOG}
opt_expr -mux_undef
simplemap
opt_expr
opt_merge
opt_rmdff
opt_clean
opt
# Map LUTs
#abc -lut ${LUT_SIZE}
abc -lut 4:6
# Check and show statisitics
hierarchy -check
stat
# Output netlists
opt_clean -purge
write_blif ${OUTPUT_BLIF}
GMT+8, 2025-9-14 02:59 , Processed in 0.010176 second(s), 3 queries , Gzip On, Redis On.
