查看: 3619|回复: 10
[资料] A Handbook of OP-AMP by Analog Devices engineer
发表于 2021-12-15 03:42:42 | 显示全部楼层 |阅读模式
Book name: "Op Amp Applications"
Outline
Chapter-I: Op-Amp Basics
Chapter-II: Specialty Amplifiers
Chapter-III: Using Op-Amps with Data Converters
Chapter-IV: Sensor Signal Conditioning
Chapter-V: Analog Filters
Chapter-VI: Signal Amplifiers
Chapter-VII: Hardware and Housekeeping Trchniques
Introduction to author and Analog Device
Walter G Jung, commonly known as Walt Jung, is an American electronic engineer and author. He worked for Linear Technology and Analog Devices. He has written a number of books, the most popular of which is the IC Op Amp Cookbook, which has been in print since 1974.He was named a Fellow of the Audio Engineering Society in 1979 for his work on distortion in op-amps. He also was named to Electronic Design’s Engineering Hall of Fame in 2002. He is highly regarded as a design engineer.
Publication list [Book/Guidebook/Tutorial/Handbook]
- Op Amp Applications Handbook; 1st Ed; Newnes; 2005; ISBN 978-0750678445.
- Audio IC Op-Amp Applications; 3rd Ed; Sams Publishing; 1987; ISBN 9780672224522.
- IC Op-Amp Cookbook; 3rd Ed; Prentice Hall; 1986; ISBN 978-0138896010.
- IC Timer Cookbook; 2nd Ed; Sams Publishing; 1983; ISBN 978-0672219320.
- IC Array Cookbook; 1st Ed; Hayden; 1980; ISBN 978-0810407626.
- IC Converter Cookbook; 1st Ed; Sams Publishing; 1978; ISBN 9780672215278.
- Unique IC Op-Amp Applications; 1st Ed; Sams Publishing; 1975; ISBN 978-0672211638.
Analog Device
Analog Devices, Inc. (ADI), also known simply as Analog, is an American multinational semiconductor company specializing in data conversion, signal processing and power management technology, headquartered in Wilmington, Massachusetts.
The company manufactures analog, mixed-signal and digital signal processing (DSP) integrated circuits (ICs) used in electronic equipment.These technologies are used to convert, condition and process real-world phenomena, such as light, sound, temperature, motion, and pressure into electrical signals.
Analog Devices has approximately 100,000 customers[8] in the following industries: communications, computer, instrumentation, military/aerospace, automotive, and consumer electronics applications.
** Note that both archieved and compressed version and .pdf of each chapter version are uploaded, just choose between them depending on your personal need.
Web_Ch1_final_R.pdf
1.62 MB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_Ch2_final.pdf
667.23 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_Ch3_final.pdf
566.86 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_Ch4_final.pdf
749.89 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_Ch5_final_PtA.pdf
2.92 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part-I
Web_Ch5_final_PtB_F.pdf
1.49 MB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part-II
Web_Ch6_final_I.pdf
3.21 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_Ch7_final_J.pdf
2.68 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Web_ChH_final.pdf
3.14 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
History of op-amp
Web_Front_final.pdf
115.59 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
front matter
Web_Index_final.pdf
292.2 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
[Walt Jung][ADI]Op Amp Applications_part1.7z
6.25 MB, 下载次数: 15 , 下载积分: 资产 -3 信元, 下载支出 3 信元
[Walt Jung][ADI]Op Amp Applications_part2.7z
10.59 MB, 下载次数: 15 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2021-12-15 08:17:43 | 显示全部楼层
找了好久,多谢分享
发表于 2021-12-15 08:33:02 | 显示全部楼层
原文地址https://www.analog.com/en/educat ... tions-handbook.html
我只是个知识的搬运工
Op_Amp_Applications.zip
16.78 MB, 下载次数: 38 , 下载积分: 资产 -6 信元, 下载支出 6 信元
回复 支持 2 反对 0
发表于 2021-12-15 09:34:57 | 显示全部楼层
不错
发表于 2021-12-15 10:06:24 | 显示全部楼层
谢谢分享
发表于 2021-12-15 13:04:59 | 显示全部楼层
下载看看
发表于 2021-12-15 13:27:29 | 显示全部楼层
thanks
发表于 2021-12-15 18:30:22 | 显示全部楼层
3Q for share~
发表于 2021-12-15 19:40:24 | 显示全部楼层
myee 发表于 2021-12-15 08:33
原文地址https://www.analog.com/en/education/education-library/op-amp-applications-handbook.html
我只 ...
谢谢分享
发表于 2021-12-15 19:46:56 | 显示全部楼层
我只 ...
what's the passwd for the pdf files?
GMT+8, 2025-12-25 08:29 , Processed in 0.028239 second(s), 5 queries , Gzip On, Redis On.
