查看: 2014|回复: 0
[求助] 关于UPF语法的求助
发表于 2021-11-11 17:54:05 | 显示全部楼层 |阅读模式
本人在做UPF测试的时候,发现不支持UPF3.0,所以想将语法改成UPF1.0的,但是目前遇到一个难题,在UPF1.0中,是没有add_power_state这一个commad的,所以假设我想将add_power_state用UPF1.0表示出来的话,应该怎么表示?下面是我的UPF一段:add_power_state ss_high   -state high {-supply_expr {power == {FULL_ON 1.08} && ground == {FULL_ON 0.0}}}
add_power_state ss_low    -state low  {-supply_expr {power == {FULL_ON  0.9} && ground == {FULL_ON 0.0}}}
add_power_state ss_green  -state low  {-supply_expr {power == {FULL_ON  0.9} && ground == {FULL_ON 0.0}}} \
                          -state off  {-supply_expr {power == {OFF} && ground == {FULL_ON 0.0}}}
add_power_state ss_yellow -state low  {-supply_expr {power == {FULL_ON  0.9} && ground == {FULL_ON 0.0}}} \
add_power_state PD_blue   -state PMon  {-logic_expr {ss_high == high && ss_low == low && ss_green == low && ss_yellow == low}} \
                          -state PMoff {-logic_expr {ss_high == high && ss_low == low && ss_green == off && ss_yellow == off}} \
                         -state PM1   {-logic_expr {ss_high == high && ss_low == low && ss_green == off && ss_yellow == low}} \
                          -state PM2   {-logic_expr {ss_high == high && ss_low == low && ss_green == low && ss_yellow == off}} \
GMT+8, 2025-12-25 06:49 , Processed in 0.015790 second(s), 4 queries , Gzip On, Redis On.
