查看: 2875|回复: 4
[求助] verilog代码求助
发表于 2021-9-25 19:29:04 | 显示全部楼层 |阅读模式
module top_module(
    input clk,
    input in,
    input reset,    // Synchronous reset
    output done
    reg [2:0]state,next_state;
    reg [3:0]count;
    parameter waitt=1;
    parameter start=2;
    parameter stop=3;
    parameter shuchu=0;
    always@(posedge clk)
        if(reset)
            state<=waitt;
    else state<=next_state;
    always@(*)
        begin
            case(state)
                start: if(count==4'd7)
                     next_state<=stop;
                     else next_state<=start;
                stop: if(in==1'b1)
                      next_state<=shuchu;
                      else next_state<=waitt;
                shuchu: if(in==1'b0)
                      next_state<=start;
                waitt:  if(in==1'b0)
                     next_state<=start;
                default: next_state<=waitt;
            endcase
        end
        begin
            if(reset||done==1)
                count<=0;
            else if(state==start)
                count<=count+1'b1;
            else count<=count;
        end
    assign done=(state==shuchu);
endmodule
这个是题目要求:
这个是题目要求
这个是题目要求
报错:
报错
报错
发表于 2021-9-25 20:51:42 | 显示全部楼层
    always@(*)
        begin
            case(state)
                     next_state<=stop;
                stop: if(in==1'b1)
                      next_state<=shuchu;
                      next_state<=start;
                waitt:  if(in==1'b0)
                     next_state<=start;
            endcase
        end
可以试试改成阻塞赋值
发表于 2021-9-26 11:24:09 | 显示全部楼层
2楼的说法不太准确,根据经验,组合逻辑里面使用阻塞赋值和非阻塞赋值,对于综合器和仿真器来说,没有区别,全当做阻塞赋值,我用modelsim是这样的结果;
数据流开始的判断条件:根据lz提供的资料,应该是数据由高变低,出现这种变化,是数据流的开始,这是I2C总线典型的开始bit位确定方案;
发表于 2021-9-26 14:20:49 | 显示全部楼层
module top_module(
    input clk,
    input in,
    output done
    reg [3:0]count;
    parameter wAItt=1;
    parameter start=2;
    parameter stop=3;
        if(reset)
            state<=waitt;
    always@(*)
        begin
            case(state)
                     next_state=stop;
                     else next_state=start;
                stop:
                      next_state=waitt;
                waitt:  if(in==1'b0)
                     next_state=start;
                     else next_state=waitt;
                default: next_state=waitt;
            endcase
        end
        begin
            if(reset||done==1)
                count<=0;
                count<=count+1'b1;
            else count<=count;
        end
       if(reset)
         done <= 1'b0;
       else if(state == stop && in == 1'b1)
          done <= 1'b1;
       else
          done <= 1'b0;
endmodule
 楼主| 发表于 2021-9-29 21:14:08 | 显示全部楼层
谢谢大家,我找到错误啦
GMT+8, 2025-12-25 21:35 , Processed in 0.025962 second(s), 5 queries , Gzip On, Redis On.
