查看: 8648|回复: 9
[求助] Xcelium has problem to generate fsdb file
发表于 2021-7-6 16:47:30 | 显示全部楼层 |阅读模式
悬赏100资产未解决
大神求救,   裝了xcelium license 18.03版, 也設置好 LD_LIBRARY_PATH
setenv LD_LIBRARY_PATH $NOVAS_HOME/share/PLI/lib/LINUX64NOVAS_HOME/share/PLI/LINUX64NOVAS_HOME/share/PLI/IUS/   LINUX64NOVAS_HOME/share/PLI/VCS/LINUX64:$NOVAS_HOME/share/PLI/IUS/LINUX64/boot:$LD_LIBRARY_PATH
但是還是有以下 error message..
xrun(64): 18.03-s001: (c) Copyright 1995-2018 Cadence Design Systems, Inc.
xmelab: *W,LIBLDFL: Failed to load dynamic library debpli:
        debpli.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library..
                Caching library 'worklib' ....... Done
        Elaborating the design hierarchy:
        Top level design units:
                test_dec8
  $fsdbDumpfile("./test_dec8.fsdb");
xmelab: *W,MISSYST (./test_dec8.v,13|14): Unrecognized system task or function: $fsdbDumpfile (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
If item was defined in a shared-object library, the problem could be:
libvpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library.
libpli.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library..
  $fsdbDumpvars(0, test_dec8);
xmelab: *W,MISSYST (./test_dec8.v,14|14): Unrecognized system task or function: $fsdbDumpvars (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
        Building instance overlay tables: .................... Done
        Building instance specific data structures.
        Loading native compiled code:     .................... Done
        Design hierarchy summary:
                                  Instances  Unique
                Modules:                 56       4
                Primitives:              54       2
                Registers:                3       3
                Scalar wires:            24       -
                Initial blocks:           2       2
                Pseudo assignments:       3       3
                Simulation timescale:  10ps
        Writing initial simulation snapshot: worklib.test_dec8:v
Loading snapshot worklib.test_dec8:v .................... Done
xmsim: *W,LIBLDFL: Failed to load dynamic library debpli:
xmsim: *E,MSSYSTF (./test_dec8.v,13|14): User Defined system task or function ($fsdbDumpfile) registered during elaboration and used within the simulation has not been registered during simulation.
xmsim: *E,MSSYSTF (./test_dec8.v,14|14): User Defined system task or function ($fsdbDumpvars) registered during elaboration and used within the simulation has not been registered during simulation.
 楼主| 发表于 2021-7-6 17:42:24 | 显示全部楼层
已解決!!! 謝謝
发表于 2021-8-13 21:39:20 | 显示全部楼层
请问如何解决的?我也遇到这个问题
发表于 2021-9-22 17:08:45 | 显示全部楼层
xrun 命令中加PLI的命令选项
-loadpli1 debpli:novas_pli_boot 这边目前是这样做的
发表于 2022-3-2 14:09:02 | 显示全部楼层
yllinf 发表于 2021-7-6 17:42
已解決!!! 謝謝
请问下解决方法,谢谢!
发表于 2022-4-25 17:48:54 | 显示全部楼层
:/ test
发表于 2023-6-8 18:18:02 | 显示全部楼层
厉害了!!!
发表于 2024-12-3 14:49:20 来自手机 | 显示全部楼层
nianhai1212 发表于 2021-9-22 17:08
xrun 命令中加PLI的命令选项
加了这个还是报同样的错,请问大佬如何解决
发表于 2024-12-22 11:55:35 | 显示全部楼层
试试 +nc64bit
发表于 2025-5-7 09:46:00 | 显示全部楼层
cirand 发表于 2024-12-22 11:55
试试  +nc64bit
都加了还是不行,irun可以,xrun的不行。
GMT+8, 2025-9-13 04:53 , Processed in 0.019627 second(s), 3 queries , Gzip On, Redis On.
