查看: 10666|回复: 36
[资料] NTU LDO & voltage reference(published in JSSC.2016) design PHD thesis
发表于 2021-4-3 16:57:24 | 显示全部楼层 |阅读模式
Chapter 1 Introduction ................................................................................................ 1
1.1 Motivation ................................................................................................. 1
1.2 Objectives ................................................................................................ 11
1.3 Contributions ........................................................................................... 13
1.4 Organization ............................................................................................ 16
Chapter 2 Literature Review .................................................................................... 18
2.1 Review of the design of the LDO ............................................................ 18
2.1.1 Review of the design parameters of an LDO ................................... 18
2.1.2 Review of the LDO topologies ......................................................... 23
2.1.3 Review of the PSRR mechanisms of the LDO ................................ 27
2.1.4 Review of prior-art PSRR enhancing techniques ............................ 33
2.2 Review of the design of the voltage reference ........................................ 37
2.2.1 Review of design parameters of the voltage reference ..................... 37
2.2.2 Review of the design of bandgap references .................................... 39
2.2.3 Review of the subthreshold voltage reference .................................. 52
2.3 Review of radiation effects on ICs .......................................................... 57
2.3.1 Total Ionizing Dose (TID) Effect ..................................................... 57
2.3.2 Single Event Effects (SEEs) ............................................................. 62
2.4 Conclusions ............................................................................................. 64
Chapter 3 A 65nm NMOS LDO for IoTs featuring >60dB PSRR over 10MHz
frequency range and 100mA load current range .................................. 65
3.1. Design of the proposed LDO ................................................................... 66
3.1.1. Design considerations for a high PSRR ........................................... 68
3.1.2. Design considerations for stability ................................................... 83
3.1.3. Design considerations for a low dropout voltage ............................. 89
3.2. Hardware measurements of the proposed LDO ...................................... 91
3.2.1. Static performance measurements .................................................... 91
3.2.2. Load transient measurements ........................................................... 93
3.2.3 PSRR measurements ........................................................................ 96
3.2.4. Noise measurements ....................................................................... 100
3.3. Design summary and Benchmarking ..................................................... 101
3.4. Conclusions ........................................................................................... 103
Chapter 4 A 5.6ppm/°C Temperature Coefficient, 87dB PSRR, sub-1V, rad-hard
MOSFET-only voltage reference exploiting the ZTC point of an
NMOS ...................................................................................................... 104
4.1 Investigation of the ZTC point mechanism ........................................... 105
4.2 Realization and design considerations of the proposed ZTC voltage
reference ....................................................................................................... 110
4.2.1 ZTC voltage reference design ........................................................ 110
4.2.2 PSRR and output noise ................................................................... 112
4.2.3 Process variations ........................................................................... 117
4.3. Hardware measurements of the proposed voltage reference ................. 122
4.4. Design summary and Benchmarking ..................................................... 128
4.5 Irradiation verification of the proposed voltage reference .................... 131
4.6 Conclusions ........................................................................................... 136
Chapter 5 Conclusions and Recommendations ..................................................... 138
5.1 Conclusions ........................................................................................... 138
5.2 Recommendations for future work ........................................................ 140
PhD thesis_Jiang Jize.pdf
2.6 MB, 下载次数: 387 , 下载积分: 资产 -2 信元, 下载支出 2 信元
作者PhD论文
jssc.2016.2627544.pdf
2.75 MB, 下载次数: 325 , 下载积分: 资产 -2 信元, 下载支出 2 信元
作者JSSC论文(原thesis chapter 4)
发表于 2021-4-3 21:00:17 | 显示全部楼层
kankan
发表于 2021-4-4 10:45:19 | 显示全部楼层
thanks!!!
发表于 2021-4-5 23:49:09 | 显示全部楼层
thanks!!!
发表于 2021-4-6 17:37:38 | 显示全部楼层
发表于 2021-5-20 14:51:16 | 显示全部楼层
学习,thanks!
发表于 2021-5-20 18:09:47 | 显示全部楼层
very good thesis for ldo design
发表于 2021-5-20 22:55:45 | 显示全部楼层
thx for sharing
发表于 2022-2-7 15:09:56 | 显示全部楼层
谢谢楼主的分享!
发表于 2022-2-8 00:46:04 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-24 18:52 , Processed in 0.021740 second(s), 4 queries , Gzip On, Redis On.
