查看: 1441|回复: 1
[求助] 重新open block 时序会变差
发表于 2021-3-8 13:54:18 | 显示全部楼层 |阅读模式
打开过程中多出这些警告
Information: coupling capacitance is created explicitly. (NEX-029)
Information: 221015 nets are successfully extracted. (NEX-028)
Warning: The aggressor block net 'place_opt_optlc_53695/ZN' is not valid and is skipped from crosstalk analysis of victim net 'u_cortexa7integration/u_cortexa7/u_cortexa7l2/u_cortexa7l2noram/u_ca7scu/u_ddi/clock_opt_opto_ZINV_inst_193113/ZN' (TIM-107)
Warning: The aggressor block net 'place_opt_optlc_53275/ZN' is not valid and is skipped from crosstalk analysis of victim net 'u_cortexa7integration/u_cortexa7/u_cortexa7l2/u_cortexa7l2noram/u_ca7scu/u_ddi/clock_opt_opto_ZINV_inst_193113/ZN' (TIM-107)
 楼主| 发表于 2021-3-8 13:59:30 | 显示全部楼层
man 了一下TIM-107,   TIM-107  (Warning)  The  aggressor  block  net '%s' is not valid and is
       skipped from crosstalk analysis of victim net '%s'
DESCRIPTION
       The victim net is coupled to  an  aggressor  block  net  which  is  not
       present.  This will happen because of dangling connections at the phys-
       ical hierarchy.
WHAT NEXT
       Check the set up for the design.  Check  if  the  design  has  physical
       hierarchy and the net connections are defined properly.
GMT+8, 2025-11-1 08:14 , Processed in 0.013628 second(s), 3 queries , Gzip On, Redis On.
